Snapped Locking Lug :-(
Yep, changing wheels on the Carrera, one of the locking lugs snapped, right at the botton
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
a.k.a. G-man
Wasn't there a guy on an a Honda or VW forum who took a sawzall to his wheel and completely destroyed it because he couldn't get the bolts off???
I can't remember what the thread was called or I'd post a link. I am afraid you'll have to go the same route, Byron... Your Fuchs is fuched... ![]()
Сидеть, ложь, Переворачиваться |
I've seen snapped lug nuts drilled out a couple of times. I believe the gentlemen used a 3/4" hole saw. Must be extremely careful to get it started correctly. Also check on the size I'm not 100% sure 3/4" is correct.
Friend of Warren
Before you go to drilling, try using a bolt/nut remover socket. Several people have had success with them. Sears sells a kit for $30.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I had this happen last year. Some numbskull used air to tighten them (That would be ME) LOL. I bought a set of cold chisels, a few drill bits, about 10 little stone grinders in various shapes for my dremel, extraction tools, etc (about $150 was spent on tools).. and about 12-14 hours later... mostly with the dremel stones, it was off with NO damage to the wheel. I bought a new stud from our host and all is well. The key here is to go very slow and deliberate. What I did in essence was use a pointed dremel grinder and hard drill bits made to drill out bolts to drill/Grind out the stud from the middle of the broken nut. The first 4 hours I just banged on it with a cold chisel and got NO WHERE. I bought several of those extraction tools pictured above, broken nut removal tools like those pictured above... even the $80 deal made for this very thing... but none of those worked for me. So the dremel grinder on the stud and nut was effective. You need to use the chisels along with the drill/dremel... but youll get there. Just remember there is no rush. About 1/2 way thriough the second day you will be ready to shoot yourself. Just drink 3-4 beers and take a deep breath.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 01-13-2010 at 07:01 AM.. |
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
![]() ![]() If you do decide to take a saws-all to your Fuchs, please have the camera ready.
'88 Carrera
I had a similar problem in that 2 of the studs on the key for the wheel lock broke off. I took the car to a mechanic who use the key (with the remaining 2 studs) and got it off, in seconds, with an impact wrench). I promptly purchased 4 new lug nuts from PP. Mike |
Pound a socket on there that is has a slight interference fit, and back the nut out. Simple, done a few times before.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
We just used JW's hole saw method this past weekend. The original lug nut had sheared in half. The hole saw worked very well, even for a first try. We didn't touch the wheel.
The photo below shows the part of the nut that snapped off (1), the outer part that started to spin just as the hole saw "broke through", and the inner part that was not cut by the hole saw (3)(the ID of the saw is slightly larger than the lug). I was careful, so the wheel didn't even get nicked. Instead of using a sharpened pick to pull out the inner part left on the lug threads, I wrapped a piece of shop towel over it and grabbed the shop towel with a pair of needle nose pliers. I was able to turn the inner part off the lug in one piece. If you look closely (it's not a very good photo), you can still see the threads intact on the inside of (3). The screw on the side of the hole saw mandrel is for removing the pilot drill. You can't use a pilot drill while you do this, but you don't need one--the lug pilots the hole saw. I learned two important lessons: 1. The hole saw method works. 2. Next time I'll use more heat and PB Blaster so that I won't break the lug nut in the first place.
-Tom '73 911T MFI - in process of being restored '73 911T MFI - bare bones '87 924S - Keep's the Porsche DNA in my system while the 911 is down. aka "Wolf boy" |
Wow. thats Great! Why didnt someone tell me about this method?
![]() Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Excerpt from factory manual:
but I really need to wait for it to warm up before I try again) then back to the Toy, I mean tool store.Quote:
I was removing by hand, Snap-On 19mm deep 1/2 socket and it snapped right off, at the base of the hexed sides... Thanks for the input & I'd remove the trailing arm before I cut any of my Fuchs
America tires use these on my cars (a little longer) several times and it worked everytime. Hammer it in, air impact gun. It'll stuck in the tool. hammer them both on the ground. They will separate.
Once, another place weld another nut on the stripped one. I don't like this approach as the tool below. Clean and quick.
Fat butt 911, 1987 |
Registered Abuser
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
EMT/TechRescue Instructor
I would use a socket that fits it snug and tap it onto the broken lugnut. You could even grind a slight taper to an old socket leaving a little of the hex shape on the inside to improve grip. Keep in mind that the harder you drive it on the tighter it may become on the stud. The lug is soft and it will compress against the stud.
David 1986 Iris blue 911 Cabriolet 2017 Ram 1500 Night edition 2025 BMW X-5 |
I've been thinking of ordering this set...
IRWIN 5-pc Lugnut Specialty Set Same principle as the Sears set above, only these begin with a 19mm (3/4" size) and go larger. Also, deeper flats for more grip with a socket and a 1/2" breaker bar. Not cheap at over $100 for the set, but a lot less expensive than a new fuchs!
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 01-13-2010 at 06:48 PM.. |
