Snapped Locking Lug :-(
Yep, changing wheels on the Carrera, one of the locking lugs snapped, right at the botton
Old 01-12-2010, 11:58 PM
a.k.a. G-man
Geronimo '74's Avatar
Wasn't there a guy on an a Honda or VW forum who took a sawzall to his wheel and completely destroyed it because he couldn't get the bolts off???
I can't remember what the thread was called or I'd post a link.
I am afraid you'll have to go the same route, Byron...
Your Fuchs is fuched...
Old 01-13-2010, 03:07 AM
I've seen snapped lug nuts drilled out a couple of times. I believe the gentlemen used a 3/4" hole saw. Must be extremely careful to get it started correctly. Also check on the size I'm not 100% sure 3/4" is correct.
Old 01-13-2010, 04:05 AM
Friend of Warren
Before you go to drilling, try using a bolt/nut remover socket. Several people have had success with them. Sears sells a kit for $30.
Kurt V
Old 01-13-2010, 05:03 AM
brads911sc's Avatar
I had this happen last year. Some numbskull used air to tighten them (That would be ME) LOL. I bought a set of cold chisels, a few drill bits, about 10 little stone grinders in various shapes for my dremel, extraction tools, etc (about $150 was spent on tools).. and about 12-14 hours later... mostly with the dremel stones, it was off with NO damage to the wheel. I bought a new stud from our host and all is well. The key here is to go very slow and deliberate. What I did in essence was use a pointed dremel grinder and hard drill bits made to drill out bolts to drill/Grind out the stud from the middle of the broken nut. The first 4 hours I just banged on it with a cold chisel and got NO WHERE. I bought several of those extraction tools pictured above, broken nut removal tools like those pictured above... even the $80 deal made for this very thing... but none of those worked for me. So the dremel grinder on the stud and nut was effective. You need to use the chisels along with the drill/dremel... but youll get there. Just remember there is no rush. About 1/2 way thriough the second day you will be ready to shoot yourself. Just drink 3-4 beers and take a deep breath.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 01-13-2010, 05:51 AM
bdisco's Avatar
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
So, Dont buy a VW - Honda-Tech
If you do decide to take a saws-all to your Fuchs, please have the camera ready.
'88 Carrera
Old 01-13-2010, 06:06 AM
msk1986911's Avatar
If that doesn't work, how about a holes saw slightly larger than the lug?
I had a similar problem in that 2 of the studs on the key for the wheel lock broke off. I took the car to a mechanic who use the key (with the remaining 2 studs) and got it off, in seconds, with an impact wrench). I promptly purchased 4 new lug nuts from PP.
Mike
Old 01-13-2010, 07:49 AM
Jeff Alton's Avatar
Pound a socket on there that is has a slight interference fit, and back the nut out. Simple, done a few times before.
Cheers
www.turn3autosport.com
Old 01-13-2010, 08:05 AM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
We just used JW's hole saw method this past weekend. The original lug nut had sheared in half. The hole saw worked very well, even for a first try. We didn't touch the wheel.
The photo below shows the part of the nut that snapped off (1), the outer part that started to spin just as the hole saw "broke through", and the inner part that was not cut by the hole saw (3)(the ID of the saw is slightly larger than the lug). I was careful, so the wheel didn't even get nicked.
Instead of using a sharpened pick to pull out the inner part left on the lug threads, I wrapped a piece of shop towel over it and grabbed the shop towel with a pair of needle nose pliers. I was able to turn the inner part off the lug in one piece. If you look closely (it's not a very good photo), you can still see the threads intact on the inside of (3).
The screw on the side of the hole saw mandrel is for removing the pilot drill. You can't use a pilot drill while you do this, but you don't need one--the lug pilots the hole saw.
I learned two important lessons: 1. The hole saw method works. 2. Next time I'll use more heat and PB Blaster so that I won't break the lug nut in the first place.
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 01-13-2010, 08:26 AM
brads911sc's Avatar
Wow. thats Great! Why didnt someone tell me about this method?
Old 01-13-2010, 08:49 AM
JWest's Avatar
Excerpt from factory manual:
James
JWest Engineering
Old 01-13-2010, 10:27 AM
Cheers
Tried that, no luck but I really need to wait for it to warm up before I try again) then back to the Toy, I mean tool store.
I was removing by hand, Snap-On 19mm deep 1/2 socket and it snapped right off, at the base of the hexed sides...
Thanks for the input & I'd remove the trailing arm before I cut any of my Fuchs
Old 01-13-2010, 10:50 AM
rnln's Avatar
America tires use these on my cars (a little longer) several times and it worked everytime. Hammer it in, air impact gun. It'll stuck in the tool. hammer them both on the ground. They will separate.
Once, another place weld another nut on the stripped one. I don't like this approach as the tool below. Clean and quick.
Fat butt 911, 1987
Old 01-13-2010, 11:35 AM
Registered Abuser
MT930's Avatar
I have done this it works like the Cat's A$$ Thanks JW It's the less risk method
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 01-13-2010, 11:57 AM
EMT/TechRescue Instructor
86911cab's Avatar
I would use a socket that fits it snug and tap it onto the broken lugnut. You could even grind a slight taper to an old socket leaving a little of the hex shape on the inside to improve grip. Keep in mind that the harder you drive it on the tighter it may become on the stud. The lug is soft and it will compress against the stud.
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 01-13-2010, 04:44 PM
pwd72s's Avatar
I've been thinking of ordering this set...
IRWIN 5-pc Lugnut Specialty Set
Same principle as the Sears set above, only these begin with a 19mm (3/4" size) and go larger. Also, deeper flats for more grip with a socket and a 1/2" breaker bar. Not cheap at over $100 for the set, but a lot less expensive than a new fuchs!
Old 01-13-2010, 05:15 PM
