Gearbox oil
What do you guys use as gearbox oil on the pre-964 cars? I can't get Swepco here in Brazil, so this is not an option.
Is it Ok to use synthetic based oil on the older gearboxes?
Thanks in advance
http://917burger.blogspot.com
Old 01-17-2010, 09:49 AM
dsmyth's Avatar
I have used a product called syncroshift 2 . I found it worked better than the Swepco for me. I dont know if thats available down there>
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 01-17-2010, 10:05 AM
Senior Advisor
James Brown's Avatar
It's more specific to what transmission you have rather than what model car it is. For the 915 trans. it's Sweptco or any approved gear oil. The G50 needs synthetic fluid like M1 gear oil. You can order Sweptco from our host but wondering how much is shipping to Brazil?
08 Cayenne Turbo
Old 01-17-2010, 10:07 AM
Sorry to mention, the oil is to be used in a 915 box
The commom oils from MOBIL here are:
Mobilube 1 SHC 75W-90
Mobil Delvac Synthetic Gear Oil LS 75W-90
Mobilube GX-A 80W
Old 01-17-2010, 10:15 AM
Any good GL-5 rated non-synthetic 75w-90 will do the job.
915's really suffer with synthetic oils as they are too slippery for the Porsche baulk-ring syncros to work correctly and excess wear is the result.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-17-2010, 10:18 AM
HarryD's Avatar
Can you get Kendall?
Peter Zimmerman says: Trans oil = Kendall Three Star 80W/90 Dino - make sure you check for Limited Slip!"
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-17-2010, 10:22 AM
Thanks Steve for the input.
No Kendall here, only Mobil,Shell, Texaco, Motul
Old 01-17-2010, 10:43 AM
gearhead
This. I use Valvoline in my street driven 914.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-17-2010, 11:07 AM
175K911's Avatar
I guess I have to ask- what's cheaper, the cost of shipping a couple gallons of Swepco to Brazil, or rebuilding a 915 because it's been run with gear oil not up to the task?
I'm sure Pelican or LN Engineering could ship the Swepco to you. Or Steve Weiner.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-17-2010, 11:09 AM
Somatic Negative Optimist
Gunter's Avatar
Steve said it:
"Any good GL-5 rated non-synthetic 75w-90 will do the job."
And JW uses that same oil and we all know about his reputation and experience with 915 transmissions.
He rebuild my 915 and didn't recommend Swepco on the grounds that the extra expense wasn't justified and GL-5 rated 75W90 was just fine.
I think that Swepco is mistakenly regarded is some kind of miracle fluid that will rectify problems in a 915 and avoid rebuilding.
911GT2: Can you get a GL-5 rated 75W90 or 80W90?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-17-2010, 11:29 AM
I use Valvoline standard 80-90W gear oil.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-17-2010, 11:34 AM
Yes, I can get a good GL-5 85W90.
Old 01-17-2010, 11:38 AM
Gunter's Avatar
Brazil should be hot enough for 85W90.
Here it's cooler and 75W90 is the norm.
Enjoy.
Old 01-17-2010, 11:56 AM
Thanks guys!!
Old 01-17-2010, 12:12 PM
nineball's Avatar
i use this and have had no problems at all.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-17-2010, 01:26 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Synthetics can leak from older gearboxes - some of the gasket technology used back in the day wasn't very resistant to synthetics.
Michael D. Holloway
https://5thorderindustry.com/
Old 01-17-2010, 01:37 PM
