Front Strut repair
79 911 I'm trying to tighten the NUT on the front strut but the entire shaft of the PISTON turns. Is there a tool that hold this PISTON while tightening the NUT? Or, is there something else wrong with the strut?
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
Czar of C.R.A.P.
Might not be of much help but I always just use a impact gets it tight without the need to hold the shaft.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
dont break off that little tab!!
impact is good idea
Ed M 86' Coupe |
Member 911 Anonymous
See that notch on the inverted washer? place a socket and a piece of 1/4" sheet metal behind it and up to the fender wall to keep the piston from spinning while you torque to spec.
If you have a odd short socket it would help even more. Hope that helps, PAG uses a spanner wrench to keep the washer in place ergo piston in place. over,
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Giant channel locks on the big washer, maybe a pipe wrench. If you can hold the big washer, it will stop the strut from rotating.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Formerly known as Syzygy
I just use a set of large jaw vice grips to hold that washer from turning.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Under the radar
Koni says DO NOT use an impact on the sport shocks.
Certainly, a large pipe wrench (protected a bit) did the trick easily. No impact wrench stuff.
Torque to spec on reinstall. Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I use an impact wrench but just until the nut starts to seat. Once you get to that point, you can usually use an orcinary box wrench without spinning the shaft.
I can see Koni's point as I snapped off the tab on my 914 many years ago - now I am just extra careful and don't use the impact wrench for torquing. |
Impact or over tightening can split the threaded shaft. Remember that the shaft is hollow in that particular shock. I have one that is totally useless in my attic because of tightening too much and splitting.
Czar of C.R.A.P.
Not to hijack but how many people line up the notches so they point the same direction. I like mine pointing forward.
The biggest problem with impact is that if you spin the shaft, you spin the piston and ruin the seals.
I thought the purpose of using an inpact wrench was to spin only the nut and not the shaft. As the original poster stated, he is using an ordinary wrench and the whole shaft turns preventing him from getting the nut on.
Get this tool and you'll be all set Pelican Parts.com - Shock Absorber Tool |
