AC Compressor rebuild for an '84 Carrera
I have an '84 with a Nippondenso compressor and I'm still running R12
I'm debating starting in on compressor rebuild. I am curious if anybody has used the tech article to perform the shaft seal R&R, what your results were and how well it held up. I'm sure I have a shaft seal problem because I can actually wiggle the pully and hear freon leaking as I do. As I see it I have the following options in order of cost: 1. Try the rebuild procedure 2. Pick up a re-manufatured compressor on Ebay 3. Purchase a new replacement Sanden 507 Any thoughts? Also did you replace your receiver/drier at the same time? Thanks for any insight.
'73 914 2.0, '74 911 Coupe, '74 911 Targa '78 924, '84 944, '86 944 Turbo, '84 911 Coupe '84 944 (current), '96 993 Coupe (current) '73 911T Coupe (current) '88 930S M505 (current) |
I replaced my Nippo 5 years ago with the Sanden and R134 and have never looked back. I have a cab so the AC works overtime when it is sunny and hot with that black blanket over my head and I get good cool air. I have not done the conversion yet on the lower bow tie vent, but will this summer just to add to the air flow. Also, I did replace the dryer. the dryer should be changed anytime you expose the system to the atmosphere. There is a different oil needed for the R134 system, but if you buy a Sanden it comes with that oil.
I had the system checked for leaks a few months after I did the conversion because it seemed I had lost some R134 and they could find no leaks at any joint or at the compressor. The guy said that the hoses tend to hold R12 molecules better than R134 molecules. I guess there is some diffusion of R134 through the hoses over time. I now recharge the system in May and have to do it again in August if I drive the car every day, which I tend to do. Each time I recharge it takes about 1/2 to 3/4 of a can and I have great cool air again. Good luck
1984 3.2 Cab (now toy) 1975 911S (old toy) Mercedes E350 W4 (snow car) 2007 911 Turbo (water and air pumper) 2012 Panamera 4S (for the wife, I swear) |
Had the same dilemma a year ago and posed the same question.
The most helpful answer was from Kuehl: "Success in "rebuilding" the Nippondenso will depend upon: The condition of the pistons, bores and swash plate. Since the Nippon does not have rings on the pistons or sleeves in the bores, what you see is what you get; if you have scratches or excessive wear it is not worth "rebuilding" (or what we really mean "repairing"). You are limited in your repair to: replacing the nose seal assembly and case o-rings and maybe the shaft bearing and swash plate bearings. If the nose seal is throwing oil you have to consider if this is because: A) The system had a "hic-cup"; meaning a one time high side overpressure situation that allowed oil and gas to vent out, B) The system is running at excessively high pressures for various reasons, C) The shaft-seal contact area or surface is rusted or pitted, or the carbon bearing is shot Figure you will spend, if you are equipped to rock & roll with a repair, at least 3 hours to remove, clean, disassemble, clean R&R subcomponents, re-assemble and replace the current unit. If you are running a Nippon we would assume you have a 84-89 3.2 (or euro turbo). The Sanden will not simply "bolt on". The mounts are different so you will need an adapter plate, and the high side hose fitting for the stock Nippon is typically a 45 deg for non-turbo; you have to consider if hose will angle properly. A "new" Nippon without a clutch ranges usually ranges from $399-499.00 and with a clutch from $499 and up. Depending upon the condition of your clutch assembly and bearing in the pulley, you may or maynot have to replace the clutch. And you will need a new drier for safe measure, a few o-rings for the hose connections and about 6 oz of ac compressor oil (typically and ester works great for either R12 or R134a)." In the end I couldn't be sure a rebuild would last & since I didn't want to be constantly fixing/replacing some component I opted to replace compressor (Sanden), evap, fr condensor, hoses, added a procooler & switched to 134a. It will be 107 in Tucson today & my AC works just fine. Regarding the R/D, if the system has been leaking you should probably replace it.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Or you can be a smart ebay shopper and buy a 507 for $125 and get your local hydraulic shop to put you a 45 deg. fitting on for $10, fab up your own adapter for $10 of metal, buy a new drier for $30, draw a vacuum and put 134a or one of the other unmentionables (Freeze 12) in it for far less. The Nippondenso is a great compressor it just is a little more of a challenge for us DIY to rebuild.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
For those who haven't seen it, here's the tech article on rebuilding the Nippondenso compressor. It seems pretty DIY-able. I'd give it a go if your compressor was in otherwise good shape and working well before it crapped out.
Scott
1984 Targa |
1984 Targa |
The only glitch I had rebuilding was finding a internal snap ring
plier with long enough points to reach the front snap ring that holds the clutch on. Otherwise its less than $40.00 bucks for parts. Keith Epperly 87 slant nose turbo look carrera cabriolet |
Throw it on the ground!
I'll be replacing my evap, front condenser, adding an underbelly condenser & Procooler and fabricating all new barrier hoses this winter. At that point, every component in my system will be new except for the compressor. I'm also considering converting to 134a so the entire project will be DIY friendly (except for evacuating the old R-12). Since 134a runs at a higher pressure, putting addl strain on a 20 yr old Nippo seems ill advised. I'll probably go ahead and replace with a Sanden 507.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I haven't pulled the trigger yet but I tend to listen to my wrench and he'd prefer I stick with a new Nippondenso along with a new dryer. He isn't a big fan of the Sanden. I'm not looking for ultimate AC since it isn't a daily driver.
If you pay attention to the procooler info, you will find you actually use less freon and at lower pressures.
forgot to mention, basic repair for a nippondenso is to replace o-rings and the front carbon bearing/seal . Besides cleaning out the old gunk thats about it!!
Keith,
You have me thinking about trying the rebuild again first. My symptoms are a small leak at the shaft seal I presume. The compressor and clutch run fine but you can hear the leak at times when the car is off and you can actually make it stop just by pushing in with hand pressure on the clutch. Does this sound toy you like a candidate for a rebuild?
Sounds like you just saved about $300.00, I take my advisory fee in good old
93 octane! Yes Thats all I did. The ONLY ISSUE IS the front carbon seal and getting it clean internally. Before you remount add about 2-3 Oz's of your flavor of oil right into the ports, much easier whe the compressor is off car. Another secret, when you are tightening all the fittings that have o-rings, don't turn the o-ring just allow them to compress, not twist. Keith Epperly 87 slant nose turbo look carrera cabriolet |
Ran across this detailed compressor rebuild procedure while surfing this AM and thought I'd post it here:
http://homepage.ntlworld.com/simon.stirley/htmlman/acpump.html
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 03-01-2008 at 07:50 PM.. |
Member 911 Anonymous
Hey Keith,
My Compressor started to make a rattling noise while AC is off, I suspect the Rotor Bearings. Can you post the link where you got your parts for the Denso Compressor? TIA, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
MBruns for President
I can tell you that you'll have less parasitic draw from the Sanden than the nippondenso. My car has 993 cams which are right on the edge of motronic driveability - as in - when you take your foot off the accelerator the revs will drop to nothing - my steve wong chip catches it and keeps the motor running. When I was running the nippondenso - my car would occasionally stall because of parasitic drag - I do not have these issues with the Sanden.
- Just one man's experience.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I agree with the Sanden Upgrade, but I want to try to fix the Denso before I have to evacuate the R12, replace the Dryer, evacuate the air and refill.
Monkey Butt Forespin
FYI, I removed the AC from my 84, still have the compressor sitting on the shelf. Was going to eBay it someday, but if you need it, let me know.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Pmed you Fred
BTW, just found a local parts store that has the clutch rotor bearing for $35, is that too much?
