Hey Doug,
You are doing a hell of a job there. What kind of undercoating are you using and what seam sealer? Keep up the good work. Thanks
Mike '75 911S '76 911S |
Hey I wouldn't be Yawning! Great story and thanks for sharing
Keepin' it Simple...
To answer some questions...
The seam seal is a FLAPS product... 3M's Dynatron. Comes in a caulking tube, ends up on your fingers (and the car). Right or wrong, that's what is on there; no going back now... In reference to my thread title... like I said at the beginning, I have had the car for 2 years and I had wanted to start a build thread for a while. In the meantime Lars/speedo, Neilsen, Matt Cooley, etc. were busy posting their SWB builds and I thought to myself, "shoot, lots of folks are doing these cars... it may be old news/boring by the time I get around to posting my build". Silly me... you folks never get tired of this stuff (and neither do I).
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
More work out back...
Spent a lot of time this week working in the engine bay. Here are some highlights:
- Installed the engine sound pad (911-556-891-01-M260 from our host) using 3M Super Weatherstrip and Gasket Glue. Buy 2 tubes... I used up one yellow tube, wished I had used black, so I bought black to finish up the edges. - Installed the engine bay perimeter seal. Thought it might put up a fight, but it took less than an hour to get it all in. New/soft rubber is refreshing to work with... - Installed OEM "Sport" motor mounts. - Started the fuel system build up (more on that later). Some pics: ![]() ![]() ![]() One other job that got done: A cool thing happens on the early cars when you decide to go with an upgraded ignition system and install an alternator w/ a built-in voltage regulator... there is not much stuff to mount on the LHS of the engine bay! The MSD and coil were the ones that came with the car and seemed like a good choice, so I kept them and made a custom panel to support them. Back when I was cleaning up the engine bay areas, I used a template I made from a 71 panel to help spot in the mounting holes, then moved to a template for the panel I wanted to make, and ultimately to a bare custom panel (1/16" thick alum sheet) that a buddy made for me since he had the material handy: ![]() Fit checked the bare panel: ![]() Looked okay, so I mounted the components: ![]() ![]() and bolted it in place: ![]() I will terminate and clean up all the wiring after the motor goes in and I can make sure I got it all right.
Noice!!!!!!!!!!!!!!
Very NICE!!
Keep up the good work. I want a ride when done!!! Q
Quincy Fountain Valley, CA '83 SC, '13 P-GTS "Air cooled, fountain pen guy, living in a water cooled, iPhone world" |
subscribed
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver 1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green 1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet |
nice
Looks great Doug. I need to get my rear in gear so I can catch up!
-Dave.
--Prescott Pelican Posse #666-- -00 M Coupe - Sadly sold, damn I miss this car. -90 325is - Turbo in the works. -07 F150 FX4 |
Well Done!
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Fuel System Coming Together at Last…
I worked on a few other little things this week, but mostly I was gathering up the last few bits needed for the fuel system and installing as much as I could on the car. The main components are as follows:
1. New SC-style CIS gas tank 2. Carrera fuel pump 3. Added a return line to the tunnel (from a 71T) 4. Generic in-line fuel filter 5. PMO fuel pressure regulator (FPR) 6. Generic 50 psi 5/16” ID rubber fuel line I think that means parts from all 911 generations from 65-89 are represented! Here is how it looks installed in the rear of the car: ![]() And here is the stuff up front by the tank. The lines from the pump to the tunnel are always “fun”: ![]() ![]() One little detail I forgot to add to the car before I sealed up the front was the L-bracket that is used to support the top isolator on the factory fuel pump bracket. I decided to make a custom one using pipe strapping that hooks back to the aluminum cross member. Nice and tight fit, so it should do the trick: ![]() On a side note, I decided to use rivnuts to hold the FPR in place and thought folks might like to see the install steps. There were already two holes on the rear cross member that were centered on the engine bay, but I had to open them up to work with the M6 rivnuts I bought: ![]() continued...
Fuel System continued...
Here are the rivnuts and their installation tool:
![]() FWIW, I chose these rivnuts because of their ribbed shank and thin head height. They are cad-plated steel… Rivnut being set in place, and one done: ![]() Two rivnuts and a custom aluminum L-bracket for the FPR. I installed the rivnuts “wet” with some black gasket goo just in case. Very solid mount. Saved the best for last... the tank: ![]() ![]() New tank, modified by TRE, and painted/assembled by yours truly. Sorry guys, no through-the-hood filler on this R clone. Like I said for the '72 oil tank stuff, not going down that road... I am pretty much ready to install the gas tank, just going to hold off a little until I do some more work up front. It is nice to be able to stand where the tank usually sits... great access under the cowl.
One less thing to worry about...
And this morning I took care of a nagging problem in the re-geared '68 902/02 tranny that will go in the car. For those of you that have gone through upgrading the simplified differential, you can relate with how nice it is to take this picture:
![]() MANY thanks to those on the site that documented this upgrade when they did it. Sure saved me a lot of time... That's all for today. Enjoy!
AutoBahned
nice & sanitary!
BTW - how much did that rivnut kit cost? and from where? |
Rivnut Source
Installation Tool, M6, P/N 96349A764, $23.87 M6 Zinc-Plated Steel Rivnut 25 pack, P/N 95105A183, $8.82 I also grabbed some 97217A444 slotted body M6 rivnuts while I was at it... I figured they may work well on fiberglass if you back them up with a washer (assuming you can get to the backside). I am thinking license plate mounts, bumper braces, etc. Hope that helps.
Doug
1971 RSR - interpretation |
Busy Month...
Time flies! It took a while for a number of things to gel over the last month (making/painting brackets, laying out stuff and selecting parts, waiting for them to show up). You know the drill... let's see if I can get the thread caught up.
Fuel Tank Installed Spot all ready: ![]() In place: ![]() Some fit checking: ![]() And bottomside hookups complete: ![]() Went pretty smooth, just took some time to make sure it was positioned well before pinning it down.
Looking great Doug.... I wish I could show that kind of progress on some of my projects. Congratulations!!!
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
It should be easier to breath...
For some reason, the oil tank breather and the gas tank breather set-ups have taken me a LOT longer to sort out than I thought they would. So, I will do a bunch of pictures and try to articulate why I chose to do what I did.
First up, the oil tank breather... After way too much time searching, this is the tank I settled on. $80 for something like this seems real cheap to me, so this was a "buy" versus a "make". The part number for the tank is STF-5116: ![]() In this case, size did matter to me (both overall and the fittings). I had a couple locations in mind for it in the engine bay (outboard of the RHS rear shock mount or on the RHS wall ahead of the oil tank). Both spots would be a tight fit and the ~1" ID hose coming off the oil tank is pretty big (for good reason, of course). I didn't want a bunch of adapter fittings in the set-up and my preference for the location was just ahead of the main oil tank on the RHS... wanted to use that factory S-hose if I could, too. So, the 5116 fit the bill regarding size and fitting location/size... what finally made it work for me was that it came with a -12 AN fitting on it. Just so happens the OD of the male threads on a -12 AN fitting are 1.0625"... nice for that 1" ID line! So, here are the parts that will get installed and the gear to pull it off: ![]() (Like that donor bracket... license plate bracket from a trailer IIRC... should be able to get a couple parts out of that!) Here is where I want it to be: ![]() Rivnuts to the rescue again: ![]() Support bracket made, painted, and in place: ![]() And everything installed: ![]() ![]() FYI, that S-hose is part number 911.107.393.01 (usually used to go from the oil tank to the RHS of a CIS air box). REALLY glad that is done. Options down the road would be to add lines from the breather tank to the carb air filters to burn off the oil fumes (hope I don't smell them in the car with the heater on like I have read about) or mod the -12 AN fitting if I get a leak where the S-hose hooks up to those threads. All possible since the tank was made of uncoated aluminum and I have a friend that is good with aluminum welding. Those were 2 other reasons I went with that tank... Hope that saves somebody some time!
Dixie Region R Gruppe
Loving the gas tank!
Phillip
Instagram @phillipkj4 1980 911 SC Backdated Viper Green 1992 Ferrari 348TB |
