pud pud is offline
Porsche Crest jolty running engine
Hi, i have now replaced the plugs and leads but still get a jolty engine do i need to get points replaced with new electronic ones , what can it be causing this jolty engine , im hacked off with it , and so is my missus, please help us ,
Old 02-06-2010, 09:44 AM
Don't get frustrated--we've all been there. Just remember, attack only one component at a time.
Have you set the points? Replaced the cap and rotor?
Do you have an induction timing light? If not, get one. Clip the lead to each wire, one at a time, as the engine is running and see if the strobe is irregular and this can help isolate a misfire.
If all seem o.k., set your timing.
Once all this has been verified as good, move to fuel delivery. This is where a set of pressure gauges is needed. A very simple test procedure that will tell you: If the fuel pump is delivering enough pressure; if your cold start running is too lean; if your warm running is too lean--which can be the cause of your symtoms also.
Take a deep breath--it will get solved. Eliminate one variabe at a time. Finish out confirming the security of the ignition, then move ahead. Post often your results and what you've done. Lots of help awaits. Keep the Faith!
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-06-2010, 10:02 AM
What year is your car? What engine? You may not even have points.
Old 02-06-2010, 06:55 PM
