ART C.'s Avatar
Angry '71 2.2 Distributor Problem
Are there any aftermarket distributors for a 2.2l to eliminate the points? My distrib. cam shaft moves up 5mm if I pull it, and I am having engine shutdowns because of erratic point operation.
Or , is rebuilding the dist. something I can easily do?
Art
1971 911e Yellow cooling shroud
1995 GPZ1100
Old 11-27-2001, 03:51 AM
Wink
Look into 2.7 Carrera dizzy. New about $280 Call Pelican first
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-27-2001, 04:26 AM
Early_S_Man's Avatar
Porsche Crest
Art,
It sounds as if your snap-ring under the felt plug wasn't replaced, or maybe it came loose. It should be an easy fix to the 5 mm play problem.
There is quite an extensive discussion of distributor disassembly and cleaning in the following thread:
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=5432&highlight=distributor+lube
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-27-2001, 10:02 AM
