OZCarrera3's Avatar
Can I Use A Different Pulley Half?
The fan on my engine currenlty uses the standard Double Outer Pulley Half (3.125"/82mm Diameter). I much prefer the look of the earlier cars with the drilled Outer Pulley Half (3.75" Diameter) as pictured below...
My guess is that doing so will slow the fans flow rate and therefore the engines cooling efficiency. Not sure if this will be an issue as I have fitted and 11-blade fan in place of the original 5-blade - maybe the new pulley half may bring it back the efficiency of the 5-blade?
Does anyone know of any manufacturer that produces a 3.125" diameter version of this pulley? Also, would I need a new fan belt?
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 01-28-2010, 08:30 PM
OZCarrera3's Avatar
Bump...
Sheldon
'07 BMW 335i
Old 01-29-2010, 05:55 PM
OZCarrera3's Avatar
Bump...one last time.
Sheldon
'07 BMW 335i
Old 02-02-2010, 03:14 PM
KTL KTL is offline
Schleprock
KTL's Avatar
As long as the pulley keys on the fan hub properly, you should be fine. You are correct that the fan will spin more slowly. However you won't approach the lower volume of the 5 blade. The 5 blade was an intentional reduction in air volume to increase the operating temp of the engine + thermal reactor exhaust to handle exhaust emissions.
Just remember that you'll need to select an appropriate length belt (longer) when switching to the larger diameter upper pulley.
Kevin L
'86 Carrera "Larry"
Old 02-02-2010, 03:25 PM
OZCarrera3's Avatar
Thanks for responding Kevin, much appreciated.
I'll check with our sponsor to see if the key apperture is the same.
Sheldon
'07 BMW 335i
Old 02-02-2010, 03:38 PM
