917 Replica - Dual 3.0 liter engine -> flat 12
Just came across this link.
Seems cool the way they have stuck two 3.0 lites 911 together to get a flat 12 Porsche 917 replica photos - MadWhips, modified & exotic car spotting "This 917 is a Melbourne, Australia-built replica. The real 917s have a flat 12 engine. So does this, but the clever part is that it runs two 3 litre 911 engines, one of which is reversed. The two engines face each other clutch to clutch, and the one that is reversed runs backwards! Pretty smart. Together they put out about 500 BHP" Anyone know how this has been done? Extended one crankshaft and added a new clutch on the other side ? |
Almost Banned Once
Nice replica!
I wonder how they did it? How do you successfully run a 911 engine backwards? They must have modified the timing chain tensioners at a minimum not to mention the other hard stuff like... How do you connect the two cranks? How do you put a clutch plate on the front of an engine and then bolt up a trans? The trans is probably a 930 or G50. I wouldn't mind getting a proper look at this car. ![]()
- Peter |
Max Sluiter
The real 917 had a central power take off gear in the middle of the crankshaft to use the torsional vibrational node there. The dual 911 engine setup would be the same, bolting the two together in the middle with a center gear dropping down to a shaft below the engine, just like the 917. Then the shaft runs back to the transaxle joined by a small clutch (ever see a photo of a real 917 clutch?- The shaft was low so they could only use a small, multi-plate clutch for all that torque!) A Carrera GT ceramic-carbon clutch would be the best upgrade option today.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
just me
that has got to be heavy and long!
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Now in 993 land ...
This is the original:
Now in 993 land ...
That second pic is from here. Much more nice images to be had:
http://www.pbase.com/917carl/917_12_cyl_engine George |
Diss Member
It can't be that heavy...
![]() If one person can lift one side of it then two should be able to carry it out of the building. (Damn, I forgot to bring my truck...)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Senior Member
Wow. Just Wow! A thousand HP engine that two guys can carry.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
![]() ![]() seems like there are a few
"when the power came on, you needed to hold on!" (Juergen Barth) |
Max Sluiter
Actually, that one is closer to 600 hp. The turbo versions were the ones that made the big ponies.
A lot of the parts for those engines were magnesium and titanium, so that's where a lot of the weight went. JR |
Is that Carl Thompson doing the building in the photos?
'79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com |
Now in 993 land ...
![]() George |
Carl is not in any of those pictures.
Mark Jung Bend, OR MFI Werks.com |
I don't think that's Carl. Maybe Gustav Nietsche and Armando De La Rosa.
JR |
Calling all Melbourne/Down-under Pelicans!
this 917 replica is insane and a very, very cool solution to the flat 12!!! i am in love with this car!!!!! we need more info...youtube vids, driving experience info, accuracy of the chassis and body dimension, etc... WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! pcb |
Calling all Aussie/Pelican mates - need....more....info!
David 1972 911T/S MFI Survivor |
Andrew and Anthony Keiler, they will be visiting cali very soon
If the chassis is the same guys from Oz, they have an American company licensed to produce the chassis I think:
Race-Car-Replicas - 586-329-1573 - 917 Specs |
