whackit's Avatar
Carb throttle linkage adjustment.
Hi all.
I just reinstalled my throttle linkage after a complete rebuild. The carbs were switched from zeniths to PMOs so I have all the correct parts but the stroke seems really short at the pedal (full travel of the pedal is about an inch an a half). I can't figure out if there is something to adjust. I have the correct bell crank at the transmission. I am re using all my parts from the zenith linkage so it should be all correct according to Richard Parr (PMO) Both carbs have the same amount of stroke at the carb so it's not that. Does anyone have an idea how to remedy this.
have searched and there are some threads which mention adjusting travel by adjusting some rods but nothing specific.
Cheers.
1971 911E 2.7RS interpretation -- Signal Orange baby!
Old 02-01-2010, 09:44 PM
Is the crank fitted at the rear of the engine 180 degrees out. Had the same problem and that is what cured it. Difficult to find pictures of the orientation.
Barry
Old 02-01-2010, 10:46 PM
Just read my reply and even I can't understand it so I have been outside and checked mine and made a drawing of the linkage and rod positions. So rather than waste a thousand words here's the picture, hope it helps.
Old 02-02-2010, 12:10 AM
Senior Advisor
James Brown's Avatar
everything sounds correct to me, does the throttle open carbe all the way? your linkage looks correct.
08 Cayenne Turbo
Old 02-02-2010, 01:57 AM
yes, with my foot to the floor the butterflies are wide open, in fact I have adjusted the stop bolt on the pedal to limit pedal travel so I don't stress the linkage.
Barry
Old 02-02-2010, 03:45 AM
whackit's Avatar
my linkage is installed that way although I do believe the problem lies there. I have been messing with the rods on either side and it seems to effect distance.
Old 02-02-2010, 08:13 AM
Senior Advisor
Each time you adjust a rod length, you must adjust all the other rods. Meaning, shortening one=lenghing the other. Also, the rod that goes through the rear of the engine down to the throttle cable has an "elongation" that allows the carbs (or injection) to be operaited (opened) with out the throttle cable being moved. So make sure all the "slack" is out of the cable to rod linkage prior to adjusting the carbs/bellcrank assembly. Use a assistant to verify full opening of the throttle.
08 Cayenne Turbo
Old 02-02-2010, 08:25 AM
whackit's Avatar
I don't have a cable. mine is all rods (later version).
Old 02-03-2010, 06:29 PM
The problem may be at the other end where the long wire rod is on the pivot at the transmission, check to see that it is aligned correctly and is not binding at that point.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-03-2010, 06:53 PM
Senior Advisor
there all rods Wackit, If you look down on the transmission you can understand how the RODS work. If they were all solid from the gas pedel to the carbs, it would be very hard to BLIP the throttle at the engine without the device Snbush67 is talking about. You can have slack in this device that would do just what your discribing. I beleave your engine bellcrank linkage is correct, time to move down the RODS to under the transmission and into the tunnel.
08 Cayenne Turbo
Old 02-03-2010, 07:07 PM
jwetering's Avatar
Hmm....
Have you tried adjusting the rods so that when the pedal is up the butterflies are closed and when the pedal is all the way down the butterflies are fully open? That would be what I would do.
Just kidding - I have faith you'll figure this out.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 02-03-2010, 10:11 PM
