				Newbie towed home tonight
			I've had my 72 911 (first Porsche) for a couple of days. This car has a 3.0 sc conversion with I believe (CIS). Today, I took it on a 200 mile drive. After a long run I parked and let it sit a few minutes. After start up, it ran rough, sputtered, and later died on freeway.
				When I got home I started reading the threads. Spark was fine. I opened the air box to find the pop off valve completely dislodged from it's hole. Glue didn't hold. I stuck it back in and the car fired up. Does this air box need to be air tight for the car to run? Could this have left me roadside?  |
			 a.k.a. G-man
			I doubt that that was the problem, But I'm not a CIS expert.
			Not really sure what it could be though.
			Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 02-04-2010 at 01:21 AM..  |
			sounds like hot start, accumulator, fuel pump, hot fuel any number of issues .......
	have you had any one other than your self(not implying any thing ) but did you have a PPI done ? do you have a local shop around ? or a lot of times if people post their location n here people are willing to help. St Paulie and Heineken are the more popular enticements although pizza works, and Butters owner just promised cookies by mail to someone on another post ...... You are also obligated to post pictures with your first posts so that we may praise your purchase and or ridicule the previous owners style/color choices ....... Best of , Post more info as you get it and DON'T FORGET THE PICTURES < WE LIKE PICTURES>  |
			Viper,
			You might start by using the "search" feature if you think your problem is centered around your air box:I put in - "airbox pop off" and came up with this... EXPLOSIVE Airbox!!! Actually there was a whole list of relative material on your airbox and engine starting failures. Has Newbie posted pictures of his new 911, and you will get more help if you post your location.
	Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories  |
			Is this 72 911t a fair price?
	PPI done by Auto Atlanta. No problems found with engine other than a couple of small oil leaks and the need for stainless fuel hoses.  |
			 Senior Advisor
			If the pop-off valve becomes disloged allowing air to get into where vacuum is, the car will sputter and stall and not run. A CIS system requires 0 vacuum leaks to work properly. Use a good epoxy to seal the pop-off valve in the hole. Did you hear a back-fire when you started it after the long run? There kinda muffeled (or very loud), that could have fired the pop-off valve out.
			get a firm grip on how to troubleshoot the CIS system or find someone that does. it is the heart and soul of the engine and does work great but can get out of adjustment. search some threads on CIS adjustment.
			08 Cayenne Turbo Last edited by James Brown; 02-03-2010 at 09:59 PM..  |
			oh crap, is this the car that was on here a month ago in the for sale that the poster mad the engine issues with , I dont remember the posts but i am hitting the search button right now , Mitch you posted on that didn't you or does any one else remember??????????????
	Not trying to scare you but give them, us , just a minute ...I'll get right back. got to go to bed but will check in am  |
 A dislodged pop off valve will absolutely cause sputtering and leave you stranded. Epoxy that thing in there righ now and get back on the road.
	jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc.  |
			are you in GA?
 Especially if thats the car I think it might be . I am still checking  |
		 80 - the man asked this question here....There's kind of only one answer to this question. (it's yes by the way)
			I had a similar problem with my car. I had a huge backfire and had the valve come out of the hole.
			I chipped off the old glue around the hole and valve body. I then cleand the hole and valve with carb cleaner and isopropyl alcohol. Used some 400 emery cloth to rough up the valve body and the hole then used regular (not 5 minute) JB Weld to reglue the valve into place. My mixture is fine after the fix. I figure the backfiring was from the slow failure of the pop off valve glue creating an air leak.
	Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic  |
			 Senior Advisor
			Sometimes good, sound advice is just a bit off....The clue was the pop-off valve was sitting in the air box and when he put it back, the car ran. It could be a bad accumulator or 10,000 other things. firt things first.
			80-911sc, you know this car first hand? was it yours or a friends? that could be some good advice. First-hand knowledge.
			08 Cayenne Turbo Last edited by James Brown; 02-03-2010 at 10:34 PM..  |
 Good advice. At this time I would reglue the valve and check for vacuum leaks. Assuming none are found, get the mixture checked on on a CO machine. The pops are typically a lean mixture with the most likely suspect unmetered air. 72viper911t, How did the car run and was it easy to start before it died?
			Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 02-03-2010 at 11:08 PM..  |
			 grateful user
			Ive been stranded a couple time from a pop valve that came loose.  The best thing i have found to put it back in is the black urethane. (not silicon) Ive done about 5 with it and have not had a failure yet.
	fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.  |
			+1 on the popoff valve. You were spot on in your troubleshooting. Popoff valve loose = massive vacuum leak =no go. Popoff valve tight = no vacuum leak = go. Been there, done that.
			Regards, al
	[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/  |
			the airbox is the space below the airfilter.  popoff valve being sealed is essential to your car running.
	poof! gone  |
			 Dixie Region R Gruppe
			+1 on the airbox. If you are on the southside let me know and I would be willing to look at it with you. I pondered buying that same car.
			Instagram @phillipkj4 1980 911 SC Backdated Viper Green 1992 Ferrari 348TB Last edited by w21055; 02-04-2010 at 07:32 AM..  |
			Automotive Professionals in Atlanta installed the valve in September and have offered to correct (reglue) the valve free of charge, so I will take them up on that.
	80sc, if you know of some issues let me know, but I don't think the seller posted on Pelican. Btw, I'm in Smyrna, northside of Atlanta.  |
It would be worth the drive just to check out your collection and see what that viper looks like.
