Wilywilly's Avatar
Removing Annodizing
A couple of guys have praised using oven cleaner to remove the annodizing on aluminum surfaces. I tried w/o any success. Is there a specific way to do this or is this an urban legend? Thanks,
Bill
Bill B.
63 Little B Coupe
67 SWB 3.63 Hotrod
08 Cayenne S
65 F100
Old 02-05-2010, 02:03 PM
I removed mine with caustic soda which you use to declog sinks. Add a minimum of 2 layers of this with a brush mixed with little water. Be carefull since this is very toxic. Did the trick on my fuchs's
'71 911 T
Original Burgundy
Old 02-05-2010, 02:08 PM
moneymanager's Avatar
Oven Off worked for me but some report it not working for them. 3/4 applications on my Fuchs and a little fine sanding did the trick. Each "coat" needs about 20 minutes to make a dent.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 02-05-2010, 02:12 PM
tangerine911S's Avatar
I used oven cleaner with great success on the alumium hand controls on my motorcycle. Removed the black anodizing then polished them.
Old 02-05-2010, 02:14 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
NOT an urban legend, but a commonly used way to remove the anodizing from Fuchs rims prior to polishing.
The trick is to use the right kind of oven cleaner. Most won't work. The Easy-Off in the blue can ("Fume Free") won't.
The Easy-Off in the yellow can ("Heavy Duty") certainly will, and that's what I used.
Old 02-05-2010, 02:26 PM
aj88cab's Avatar
Or you could go all out and try this anodize stripper stuff. Scroll all the way down to the list at the bottom and there is an item for just the stripper. A bit more pricy than oven cleaner though.
Caswell Inc. - LCD Aluminum Anodizing Kit
I have not used this stuff. Just found it doing a search on removing chrome.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 02-05-2010, 02:37 PM
Bird. It's the word...
Fishcop's Avatar
Ditto
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 02-05-2010, 03:53 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
Yep the yellow can
when i was 13-14 years old i was cleaning my bmx bike and it had anodized cranks hubs and wheels i was having no luck with the dish soap i was using so i remember my mom spraying on the easy off and just walking away then wiping it down later. well after 20 mins or so i came back to the bike and it was covered in a blackish goo. when i sprayed it off i was devastated . i worked to summers to build this beauty and only 20 mins to destroy it.
the yellow can KILLS
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-05-2010, 06:37 PM
Now in 993 land ...
aigel's Avatar
Anodized aluminum is a thick layer of Aluminum Oxide. Best way to get it off is mechanically, IMHO.
Reading a little online will show that other stuff will do the trick. I'd try Sodium Hydroxide:
Removing anodizing from aluminum
George
81 SC (sold)
Old 02-05-2010, 06:55 PM
AUS911SC3's Avatar
Oven cleaner will only ever remove a thin superficial layer, it may look as though it has removed but in reality it hasn't as it relatively thick, It is essentially the protective component for what is quite a soft surface. I had mine fully sand blasted, outers machined, dipped then reanodised. To get the original look and functionality isn't cheap but it's worth it.
Old 02-05-2010, 07:22 PM
I believe I used the Easy-Off Hevy Duty also. Got lucky I guess.
Old 02-05-2010, 07:45 PM
3.4 Bigger is better
88-diamondblue's Avatar
Easy-Off Heavy Duty is the one that works. It contains sodium hydroxide, more commonly known as lye. There are drain cleaners that use lye as well and should work. If for some reason you have a clear coat of some type the lye will not effect paint.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 02-05-2010, 08:16 PM
Model Citizen
herr_oberst's Avatar
Speaking of bike parts, I used some Castrol Super Clean on some derailleur parts, and like carrera turbo above, ended up owing a stupid tax (paid to shimano's dura-ace division), for my efforts.
It's easy-peasy to roach aluminum
Old 02-05-2010, 08:17 PM
Fishcop's Avatar
Not trying to be argumentative, but the Easy Off oven cleaner most definitely stripped all four of my fuchs entirely of anodise (two applications). They polished up straight away - so I know the anodise was gone...
I plan to refinish my wheels as you've suggested with new anodising - I'd love to see photos of how they came out and any other advice or recommendations you might have.
Cheers
John Forcier
Old 02-05-2010, 09:13 PM
Jeff Alton's Avatar
Yep easy off works, done that. Next time I would take them to my local anodizer who does all of our new wheels and have them strip them for the same price as a couple of cans of Easy off....
Cheers
www.turn3autosport.com
Old 02-05-2010, 10:52 PM
question, i'm trying to get the anodizing removed with yellow can easy off.... i left it on overnight as some suggested, and i have some dark black spots.... did i leave it on too long? it still looks like the anodizing is still on and I've done two applications. how does one know when the anodizing has been removed? i'm ready to go down to my local lab and get some real stuff to try!!! any pics out there
Old 04-18-2013, 06:52 PM
howard freeman's Avatar
Don't use the green enviro friendly type. Use the real stuff heavy duty. Green products never work & If they do ,you must use 15 cans to get the same results as 1 can of the real meal deal!!
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 04-18-2013, 07:09 PM
proffighter's Avatar
As I do a lot of anodizing, I can give you following advise:
Remove using 10-15% sodium hydroxide solution. The process is speeding up itself, means the longer the more it acts. To have good control and a flawless result, I highly recommend to use a bath, not adding solution with a brush or so.
If the Aluminum is getting darker (up to black), the reason are alloying elements. There is only one way to remove (within seconds and perfectly):
10% nitric acid.
All these chemicals are dangerous and fast acting, so be very carefull
PS Flush with lots of distilled water after each bath
Roland
930 Turbo '81 Too many modifications to list
Old 04-19-2013, 12:04 AM
theiceman's Avatar
Originally Posted by carrera turbo View Post
Yep the yellow can
cheers ed
Great. Story . Made me smile ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-19-2013, 03:03 AM
Profighter, are u saying I left the oven cleaner on too long? I sanded some of the black spots with 600 grit water and it seem to remove the spots. How long should I leave the oven cleaner on? I'm on the verge of going down to my friendly lab and getting some sodium hydroxide and now maybe some nitric acid....
Old 04-19-2013, 10:50 AM
