Best brake manufacturers
So finally pulled my ’85 Carrera out after couple of years in storage. Took it over to Terry of Lawell Motorsports in Houston for a general look over prior to hitting the road and some track events. To no one’s surprise, all four calipers are frozen. Can’t tell if rotors are warped and thinking of replacing anyway.
So here we are…. Lots of choices for new brakes. Who/What is your favorite? (Will tally the results of everyone’s input and post summary for future ref.) Calipers: ATE – new OEM approx $190 each A1 Cardone – reman ATE cores approx $60 each Others???? Pads: BHP Performance Pagid Racing Hawk Performance Ate Original Ate PremiumOne OEM Porsche Others???? Semi-metallic or ceramic? Which product line? Rotors: Zimmermann Ate Original Ate PremiumOne Sebro Centric/Power Slot OEM Porsche Others???? Cross-drilled, dimple-driller, slotted or regular? Which product line? Brake lines: G-Stop 4 Line Stainless Steel kit OEM rubber lines Others??? |
Depends on what you need for your brakes to do.
Schleprock
Nothing wrong with using a reman caliper. Save yourself some $ and get remans.
Pads are like motor oil. Everybody has a favorite. I like OEM Mintex from Pelican for street (because they're crazy cheap) or Porterfield R4S. For track I like Performance Friction PF97 Rotors are easy. You can't beat the OEM Zimmerman for quality and durability. Ate are good too. No reason to waste your money on slotted, dimpled, cross-drilled, cryo. etc. etc. The plain jane flat-faced rotors are completely up to the task of street car use on the track. OEM Ate rubber lines work perfectly on the track. Rock hard pedal all the time and perfect fitment. I've used them for years on my car.
Kevin L '86 Carrera "Larry" |
HPS pads with Sebro cross drilled rotors
Mostly street with light track. Good balance for reasonable price.
Have been recommended Hawk HPS pads with Sebro cross drilled rotors. Any thoughts? |
Thanks KTL. Been trying to find who sell Porterfield R4S, but not having much luck.
Max Sluiter
Talk to Eric
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
