Weight !
Dumb Question !
Im curious how much does a stock 82-83 SC weigh. I always get different answers when looking it up on the web.
Also...how much does a stock Vram 993 weigh.
Im planning an engine swap and im looking for the weight differences i will incure. But i also have to account for the extra 100 lbs that the G50 transmission will account for.
Any Thoughts !
Old 02-10-2010, 11:53 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
my suggestion would be to go to your local scale and just drive on and see what it come out to. other than that you will always get best guesses on what it weighs. there are so many differences from car to car I.E. sunroof etc.
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-11-2010, 12:19 AM
FinallyGotOne's Avatar
Sc to 83 was about 2750 pounds, the 993 was 3020 pounds. But I'm thinking you are wanting to know the weight of just the engine?
I just called motomeister and they said about 450 pounds is the weight of the 3.0SC. and the 3.6 litre 993 is approximately the same weight. If your thinking about weight bias front to back ratios, I'd say they seem to be near the same.
There is some guys on here though that probably know the differences down to the ounce!
Old 02-11-2010, 08:41 AM
Porsche 993 Transmission Charts
here is a cool chart showing differences in gearing and how it helps the 993 MPH. The RS1 gear gets you to almost 50 miles an hour in 1st gear! That would be a lot of fun
Old 02-11-2010, 08:52 AM
Max Sluiter
Flieger's Avatar
mm..... Are you serious!
Old 02-11-2010, 03:21 PM
Hansv's Avatar
Hi there, Idar211;
I think 100lbs. extra weight for a G-50 compared to a 915 is a bit pessimistic; more like 50lbs. I would say. Still, a hefty penalty. Having said that; are you aware of the fact that an SC bodyshell needs some pretty heavy surgery before it wil accept a G-50?
Luft natürlich, weil es weder kocht oder friert....
Old 02-11-2010, 03:28 PM
French Import
zippy_gg's Avatar
Cool
I just called motomeister...
So, what did you call them exactly?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Greek55's Avatar
Oh Lord, I hope this doesn't end up being another Motomeister bashing.
Smoke
1982 911SC Rosewood
SCWDP # 0097
Old 02-12-2010, 06:30 AM
Originally Posted by Hansv View Post
Hi there, Idar211;
Amen on NOT using a G50 in this swap. Back in '92, I aquired a 3.6 and a G50, with the idea of installing both. Gave up after looking at the mods needed to the '80SC body, pedal assy, shifter assy, etc., and sold the G50. Installed a 915/73 LSD, and have been very happy the last 18yrs! Plus NO weight penalty!
As far as durability, PAG used the 915 derived transaxles in their race cars for many years!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 02-12-2010, 07:03 AM
AutoBahned
RWebb's Avatar
why not just buy a 964? solves most of your problems
a shop (in Nashville?) converted the body to look exactly like the Early cars ("longhood")
that will give you a more modern suspension system and wider tires as well as a stiffer body shell, which weighs little more than the shell of an early car
Old 02-12-2010, 12:35 PM
