O2 sensor?/84 Carrera
Hello. I was wondering if someone could tell me the location of the O2 sensor plug in the engine compartment. Is is on the same bracket as the cylinder head temp sensor?
Thanks,
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 02-15-2010, 07:26 PM
abit off center
cgarr's Avatar
It should be clipped to the engine comp frame just below the fuel filter and its an inline plug, at least that's where it is on my 86
______________________
Craig
G2Performance
Old 02-15-2010, 07:28 PM
Thanks Craig. I hope that's where it is on mine as well.
Chris
Chris
95 993 C2
Old 02-15-2010, 07:36 PM
efhughes3's Avatar
It will be. Be very gentle. There is a very good chance the plug will disintegrate due to age.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-15-2010, 07:42 PM
Send a message via Yahoo to shnewberry
You can see the O2 sensor shield on the exhaust on my '84 engine.
Good luck.
Seth
1984 Carrera and about 150 ziplock baggies.
Old 02-15-2010, 07:47 PM
Hendog's Avatar
Here it is on an '87. EDIT: That's the CHT sensor plug!!!
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Last edited by Hendog; 02-15-2010 at 08:44 PM.. Reason: correcting the information
Old 02-15-2010, 07:55 PM
efhughes3's Avatar
That isn't an O2 sensor plug-in Henri.
Ed Hughes
2015 981 Cayman GTS
Old 02-15-2010, 08:03 PM
Hendog's Avatar
Isn't it?
I pull that plug and measure my O2 sensor output at that point. Isn't that what he's looking for?
Henri
Old 02-15-2010, 08:23 PM
efhughes3's Avatar
His O2 sensor will plug into a socket under the fuel filter on the LH frame rail.
Ed Hughes
2015 981 Cayman GTS
Old 02-15-2010, 08:29 PM
Hendog's Avatar
OOPS! You're right. I hate giving bad information. My pic shows the CHT sensor plug. I'll go edit that. In the meantime, here's a pic of the O2 sensor plug in the engine compartment (on an '87). I did change my O2 sensor less than 2 yrs ago; you'd think I'd remember that plug
Here ya go.
Henri
Old 02-15-2010, 08:43 PM
I remember when I was confused about the O2 Sensor.
My 911 was failing smog, and I had to dive in and learn the system, then try to troubleshoot the problem.
The worst part was that the O2 Sensor plug was broken by the shop that was supposed to fix my 911.
Here's a pic of the two circuits for the 3.2 911 O2 Sensor. The plugs are located where Ed says, on the left hand side below the fuel filter.
I was able to glue the plug back together. Now I hold the O2 Sensor onto the plug with a zip tie around the rubber boot. I cut the rubber boot lengthwise to make it easier to remove next time without breaking the yellow plastic plug.
Old 02-15-2010, 10:13 PM
Thanks everyone for the replies. With the help of the pictures I have located the plug in the engine bay. I am looking to disconnect it to see if it solves a flat spot issue I have. If the plug dissolves when I check it do I need to replace it or can I run the car without an O2 sensor and avoid damaging anything?
Thanks,
Chris
Chris
95 993 C2
Old 02-16-2010, 05:03 PM
efhughes3's Avatar
You can run it without it, but I'd plan on fixing it. Your car will not run optimally, except at WOT without an O2 sensor in place. I made a plug-in connector with new male and female individual wire connectors as mine evaporated beyond repair.
Ed Hughes
2015 981 Cayman GTS
Old 02-16-2010, 05:10 PM
Thanks Ed. Will do. Is there a difference between the stock Bosch unit and the after market one (bot hare sold by our host) ?
Chris
Chris
95 993 C2
Old 02-16-2010, 05:56 PM
Chris, if you buy a Bosch O2 3-wire sensor, then it's a sure thing. You won't have any problems.
But, I would not suspect the O2 sensor in flat spot or throttle response problem. When you disconnect the O2 sensor (the sensor circuit, not the heater circuit), the voltage to the dme from the O2 sensor will be cut off. This will cause the system to run in "open loop", or in other words, the dme computer will go into a safety mode of pre-determined ignition advance and fuel injector timing, based on temperature and throttle position. This will not fix your problem unless your dme chip image for closed loop running is damaged (not likely).
I would suspect fuel delivery pressure, or maybe a plugged cat or a muffler baffle that has come loose and is blocking the exhaust gas outlet.
Here's what I would do. Warm the car, then open the oil fill cap. The engine should stumble, then recover. Replace the cap, then disconnect the small vacuum line to the fuel pressure regulator. Should stumble then recover. The second test is the rich stop test. If there is no change in idle, then I would connect a fuel pressure gauge and test the pressure both running, and with the dme socket jumpered (engine not running). The do a fuel delivery test (volume of gas over pre-determined amount of time). All of this is covered in the Bentley manual.
If these tests show no problem, then I'd remove the cat and shine a strong flashlight in there. You should see faint light. If the tests show low pressure, then you can try running some Techron or some BG 44K in the gas tank with fresh clean Premium gas. Or you might have to replace the fuel pump, depending on how bad the pressure is or how bad the engine stumbles.
Old 02-17-2010, 10:33 AM
