Hilbilly Deluxe
Installing sound pad, will this stuff work?
I am going to replace my engine sound pad while I have the engine out for a clutch job. I couldn't find any of the 3m "Super" adhesive, all I could find locally was this stuff. Will it work, or should I keep looking?
Thanks, Tom |
Senior Member
That stuff works ok for carpeting etc...but I wouldnt go through the trouble of using it with your sound pad...keep looking for the 3M product, or order it from a catalog, JC Whitney and just about any other place has it available
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
I used Dynamat for eng. comp. and trans tunnel.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
While we are on the subject - does the mat insulate the passenger compartment from engine heat as well as sound?
I'm dropping the engine too and my insulation mat has fallen. I was just going to rip the thing out and not replace it. I don't mind hearing the engine better
Eric Wolf |
The Dynamat has a thick foil that should keep out heat. Placement in trans. tunnel keeps out that trans. gear whine and road noise muffled.
Banned
About the dynamat; is it heavy? And also, did you just put it on tunnel under the carpet? And where the factory sound pad goes?
I put it outside when eng/trans was out. Then under carpets. It does have weight. I probally used 50-60 pounds worth all over
Stay away from my Member
The heavy engine compartment pad won't stay put with the regular 3M adhesive. BTDT. Lost cause.
Use the heavy-duty stuff, or "carpet glue".
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
Senior Registered User
The "Heavy Duty" 3M works great on engine pad.
Randy Jones 1971 911 |
Is the foil on the dynamat to the outside? Can it be painted. Does it have a self stick backing.
I was thinking of using it in the engine compartment, but want something I can paint.
Bob, 59 A coupe 67 911S 04 R1150RS |
Most of the Dynamat selections have foil on outside. There is one style that doesn't. Chek out their site.
Sound Pads?.................
We don't need no stinking sound pads
Keith 1979 930 2007 WRX wagon |
Bird. It's the word...
Skip the pad, they are a messy hassle. Enjoy the noise!
John Forcier Current: 68L 2.0 Hotrod - build underway |
Hilbilly Deluxe
Thanks for the replies.
Well, I already have the pad, and the engine is sitting next to the car, so I may as well put it in. I will keep looking for the good 3M stuff. Tom |
Tom,
This is the stuff you want to use: http://www.pelicanparts.com/techarticles/914_sound_pad/914_sound_pad_pic8_big.jpg It's available for sure at Napa Auto Parts and the counter guys affectionately refer to it as "gorilla snot" which will make complete sense once you start using it. Good luck. Mark Sides '82 SC Targa w/new sound pad
Mark '88 Carrera GPW Sunroof Coupe '82 SC Targa (RIP) |
I used the dynamat "hoodliner" material on
both my xj6 & 911. It is lightweight, about 5/8" thick, has the foil on the outside and is self adhesive on the back. Have had it on the jag for a year and it shows no sign of coming loose. The size that it is sold in is large enough to replace sound pad and cover the lid sheet metal on the 911. |
Author of "101 Projects"
No, this stuff won't work. WE SELL THE STUFF THAT DOES WORK! As well as 101 Projects, which has this engine pad replacement as one of the projects...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
