Hilbilly Deluxe
emcon5's Avatar
Installing sound pad, will this stuff work?
I am going to replace my engine sound pad while I have the engine out for a clutch job. I couldn't find any of the 3m "Super" adhesive, all I could find locally was this stuff. Will it work, or should I keep looking?
Thanks,
Tom
82 911SC Coupe
GTI Cup #43
Old 11-24-2001, 12:38 AM
Senior Member
That stuff works ok for carpeting etc...but I wouldnt go through the trouble of using it with your sound pad...keep looking for the 3M product, or order it from a catalog, JC Whitney and just about any other place has it available
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 11-24-2001, 04:59 AM
I used Dynamat for eng. comp. and trans tunnel.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-24-2001, 07:04 AM
ebradway's Avatar
While we are on the subject - does the mat insulate the passenger compartment from engine heat as well as sound?
I'm dropping the engine too and my insulation mat has fallen. I was just going to rip the thing out and not replace it. I don't mind hearing the engine better
Eric Wolf
Old 11-24-2001, 08:15 AM
The Dynamat has a thick foil that should keep out heat. Placement in trans. tunnel keeps out that trans. gear whine and road noise muffled.
Old 11-24-2001, 10:37 AM
Team California
speeder's Avatar
About the dynamat; is it heavy? And also, did you just put it on tunnel under the carpet? And where the factory sound pad goes?
Denis
Old 11-24-2001, 10:52 AM
I put it outside when eng/trans was out. Then under carpets. It does have weight. I probally used 50-60 pounds worth all over
Old 11-24-2001, 11:11 AM
Stay away from my Member
campbellcj's Avatar
The heavy engine compartment pad won't stay put with the regular 3M adhesive. BTDT. Lost cause.
Use the heavy-duty stuff, or "carpet glue".
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 11-24-2001, 11:59 AM
RLJ RLJ is offline
Senior Registered User
The "Heavy Duty" 3M works great on engine pad.
Randy Jones
1971 911
Old 11-24-2001, 12:01 PM
Is the foil on the dynamat to the outside? Can it be painted. Does it have a self stick backing.
I was thinking of using it in the engine compartment, but want something I can paint.
Bob,
59 A coupe
67 911S
04 R1150RS
Most of the Dynamat selections have foil on outside. There is one style that doesn't. Chek out their site.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-24-2001, 12:18 PM
Yargk's Avatar
Sound Pads?.................
We don't need no stinking sound pads
Keith
1979 930
2007 WRX wagon
Old 11-24-2001, 01:39 PM
Bird. It's the word...
Fishcop's Avatar
Skip the pad, they are a messy hassle. Enjoy the noise!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-24-2001, 07:07 PM
Hilbilly Deluxe
emcon5's Avatar
Thanks for the replies.
Well, I already have the pad, and the engine is sitting next to the car, so I may as well put it in.
I will keep looking for the good 3M stuff.
Tom
82 911SC Coupe
GTI Cup #43
Old 11-24-2001, 09:30 PM
Tom,
This is the stuff you want to use:
http://www.pelicanparts.com/techarticles/914_sound_pad/914_sound_pad_pic8_big.jpg
It's available for sure at Napa Auto Parts and the counter guys affectionately refer to it as "gorilla snot" which will make complete sense once you start using it.
Good luck.
Mark Sides '82 SC Targa w/new sound pad
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 11-24-2001, 11:07 PM
I used the dynamat "hoodliner" material on
both my xj6 & 911. It is lightweight, about 5/8"
thick, has the foil on the outside and is self
adhesive on the back. Have had it on the jag
for a year and it shows no sign of coming
loose. The size that it is sold in is large enough
to replace sound pad and cover the lid sheet
metal on the 911.
Old 11-25-2001, 08:10 PM
