Eye of the Toiger
Removing my engine and Gearbox - help needed
Any articles on how to undo the drive shafts from the gearbox I have a 915 GB I am removing need a little info on how to do it correctly.
I have read the engine removal article so far so good. Matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
It is usually a 12 point internal socket I think it is 10mm. There are 6 on each axle.
Mine were a 6 point allen head. Three of them stripped out. Only by grace of the acetone/atf penetrating oil was I able to remove them.
Just did this a few days ago. Not so hard. Larry |
porsher
my 915 has a 12mm triple square head bolts
be sure you get the correct tool I had never heard of them before but this is a porsche!
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
