Cattler's Avatar
Porsche Crest Fixing weak wiper squirt
With all of the melting snow this has become a real issue. I had wiper movement, but no washer spray for a while, even though the reservoir was full. I checked the wiring, etc., and unplugged / replugged the washer motor and it worked pretty well for a while. Now I'm back to it intermittently working and I have to pump the wiper switch on the steering column a few times to get any spray. Spray I do get usually is pretty weak.
What should I check / do to fix it?
Thanks,
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 02-20-2010, 05:09 PM
Someone has a similar problem:
No voltage at windshield washer pump
I'd first check the voltage at the terminal to the pump--it sounds like it is sporadic and when it does have voltage it may be less than 12v, accounting for the weak spray. Let us know what you find.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-20-2010, 06:23 PM
rgrimm's Avatar
Also, check the hoses. I had a problem with my headlight washers, and it turned out to be nothing more than a kink in a hose. They're old...they may not be in the best condition.
There are also check valves underneath each nozzle. They are supposed to "hold" washer fluid in the hose and not let it drain back down. One is easy to replace...the other is not so easy. Then again, I replaced the one I could get to and it didn't seem to make that much of a difference.
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 02-20-2010, 07:27 PM
Bill Douglas's Avatar
Are the jets clean? My car does this and pin shoved in the jets fixes the problem for another 12 months.
Old 02-20-2010, 09:50 PM
baq911's Avatar
So I woke up kinda goofy today and for some reason the title to this thread is a perfect "thats what she said". There are these great lines as well:
*Are the jets clean?
*Check the hoses
hehehe....sorry I felt like I had to.
YouTube - Every "That's What She Said" from The Office
Old 02-21-2010, 09:22 AM
