Highfield's Avatar
73T - P O R S C H E Scripts
Following the post by MikeB over on DDK, I decided to get out there today and do the engine lid PORSCHE script.
However, upon opening the script, I found it to be 36mm too wide !
So I used Mike's method of marking the letters on a piece of tape, but then moved each letter 6mm to the left, thus taking out 6X6mm = 36mm.
As you can see, it was a case of measure twice and fix once, but well pleased with the result.
Here are the individual letters cut and re-applied in their new position before peeling the backing from each and sticking down.
Next it is the side script.
Ian
Ian Highfield
1992 964 C2 Manual with RS Suspension etc.
1973 911T Narrow body Hot Rod with 2.7 Carrera engine and loads of period modsl - SOLD
1986 Carrera Coupe Sport with Stainless Silencer and SW Chip (256 fwbhp) - SOLD
Old 02-14-2010, 10:29 AM
Highfield's Avatar
The side script was applied to a wet door panel, as there was no way I was going to do it direct.
Getting the measurement and position took ages, but eventually I applied wet and then pressed on and use da hair dryer to thoroughly dry before removing the top covering.
This was a pretty tough job, and there are a couple of small air bubbles but it is OK as it stands.
I still have the RH one to do, and the bumper stripes (but I will sleep on that decision).
I just hope they stay stuck down !
Ian
Ian Highfield
Old 02-14-2010, 10:34 AM
rennwagon's Avatar
side scripts
Ian, Nice job all around. That looks great. Here is a look at my '73 T with the bumper stripes also applied. I had to go with red to match the interior. Cheers. Mike.
Old 02-14-2010, 10:52 AM
Highfield's Avatar
Finished off the right hand side today and then went for a run out in the Cotswolds.
Stopped at doing the bumper stripes as I want to see how I feel about it in time.
Ian
Ian Highfield
Old 02-21-2010, 10:56 AM
Air Cooled
Craig_D's Avatar
Gorgeous!! It looks brilliant. Nice job.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 02-21-2010, 11:00 AM
