83 SC
CraigT's Avatar
Question engine won't turn over
hi,
the other day got in my 83 911sc and when i turned the key, nothing! I thought that maybe my battery was dead, that i have turned on the overhead light while working in the back seat area. but nope, i had all my power, lights, radio, ect...
well, seemed like it might be my starter/solenoid. got that out and replaced the solenoid. just got it back in and when i turned the key, nothing, again!
where do i look now? is there a relay i am overlooking? all my fuses are good.
my experiance is limited but i do read and willing to learn.
all sugestions will be appreciated.
thanks
craig
Old 02-26-2010, 05:46 PM
Make My Day
wowzer911's Avatar
Can you hear the starter engage?
Did you take off starter or just the solenoid?
Could it be possible your starter is engaged and locked up with the flywheel?
I've had that happen before.
If so, put the car in gear and rock it forwards and backwards a little, then try to start.
If the starter is not engaging then I'd say it's likely electrical.
That should be pretty straight forward to go through.
74 911S Targa ROW
Building Designer/Business Owner
Old 02-26-2010, 06:03 PM
tazzieman's Avatar
Have you charged the battery overnight Craig?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
You have the yellow wire wrong.
The yellow wire goes high and the yellow/blue goes to the lower tag on the starter.
Bruce
Old 02-26-2010, 06:07 PM
muck-raker
kidrock's Avatar
you might have enough juice to run your lights, etc but not enough to turn your starter over. Give it a charge first then report back.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-26-2010, 06:36 PM
Also check your contacts and grounds, especially the trans ground strap.
Marv Evans
'69 911E
Old 02-26-2010, 08:56 PM
TibetanT's Avatar
Subscribing for information purposes.
Just a thought...ignition switch bad??
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 02-27-2010, 12:24 AM
Free minder
Aurel's Avatar
Use a remote starter
It could be bad contacts at your ignition key switch. I had this happen on mine. I would turn the key and nothing...To check for that, just bypass it by connecting a remote starter to the starter solenoid. If it cranks like that, you got your culprit. Unplugging and replugging the key switch was the fix for me.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 02-27-2010, 05:03 AM
