175K911's Avatar
I'm curious. Do you have a pic of a G50 reservoir?
No actual pic, but .....
From our host:
Pelican Parts - Product Information: 911-355-017-04-M100
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-01-2010, 09:14 AM
Originally Posted by GaryR View Post
I use one of my Longacre bleed bottles that has a magnet attached and stick it to the steel body in front of my spare, works perfectly and never moves. Even if it fell over it wouldn't leak as it's sealed..
An equivalent is the brake bleeding bottle from HF. The nipple and supplied hose fits the reservoir nicely.
This takes care of fluid expelled by G-forces. If large quantities of BF are expelled, you have other brake system issues (e.g. excessive heat).
MHO,
Sherwood
Old 03-01-2010, 12:41 PM
Smart quod bastardus
fredmeister's Avatar
Has anyone ever measured how hot the fluid gets inside the MC reservoir after running hard?
I am surprised that the fluid transmits that much heat all the way up to the reservoir from the caliper.
interested in seeing some temp data for this.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-01-2010, 01:07 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
I also route mine through a handy hole in the bootom of the smuggler's box. Just the right (small) size for the overflow line.
Not much comes out, just a little drip here and there after sitting after a hard drive where the lateral G's gets it into the overflow tube.
ditto...but i like this catch bottle i see everyone using. i keep running over the pan i have in the garage
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 03-01-2010, 04:16 PM
BTW, a friend races his street-prepped car in POC/PCA events and runs his overflow tube into a 35mm film canister. Seems to have enough capacity.
Sherwood
Old 03-01-2010, 04:37 PM
G50 brake/clutch fluid reservoir photos
Here are a couple. Note that the brake and clutch each have their own compartments, but the wall separating them has holes in it to allow sharing fluid. It should also significantly reduce the amount of "slosh" that will get to the overflow.
Mike
'87 911
Old 03-01-2010, 06:14 PM
burgermeister's Avatar
Note that the G50 reservoir vent does not originate at the side of the reservoir. There appears to be an internal passage to somewhere near the center of the reservoir.
On the 915 reservoir, taking the vent line out the driver side, routing it rearward, and then up, might not prevent fluid leakage. A RH turn would fill the line, and subsequent accel might push the fluid in the line over the hump.
A better solution would be to route it straight up and over the top of the reservoir. It would be difficult to get sufficient g-forces to push the fluid over that hump. Another possibility would be to get some very thin copper tubing that fits inside the nipple and push it through to extend the vent line pickup point to somewhere in the middle of the reservoir where brake fluid is least likely to be.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 03-02-2010, 02:22 AM
175K911's Avatar
Mike- thanks. That helps a lot. Quite a difference from the 915 reservoir setup.
Burgermeister- I tried routing up over the top but it really didn't make any difference. I agree a tall loop up high would be the solution, but the top of the reservoir cap already is extremely close to the hood itself.
I may just order the G50 reservoir and bracket from our host and give it a shot. Certainly can't hurt.
Ed
Old 03-02-2010, 05:15 AM
MBruns for President
JeremyD's Avatar
I never had this problem with the G-50 reservoir - But from the looks of these solutions - Number one issue would be heat management. #2 would be fluid management - #3 I'd look for an extra brake bleeding bottle with the magnetic attachment. Seems like the most logical solution.
Old 03-02-2010, 06:17 AM
175K911's Avatar
Jeremy I'd agree re the G50 reservoir. I've got #1 covered with both the 993 control arm deflectors blowing air to the calipers and air ducting from the inlets in the Yellowbird valance through Smart Racing manifolds into the eye of the rotors. #2 is covered with either Motul600 or Brembo racing. Never ever boil fluid, just loose the fluid.
Ed
Old 03-02-2010, 06:34 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
what would happen if you just blocked off the vent line?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 03-08-2010, 04:11 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
I tried that with a pair of vise grips once while trying to sort out the issue. The brakes worked fine on the first application. the second time i went to the pedal i had to pump it to get any braking. the third time i needed to pump even more. Not the direction i wanted to head so i pulled off the road and removed the clamp and all went back to normal. This is my $.02 non scientific theory. The pistons will extend with the hydraulic pressure but since there is no vent the fluid will retract to its previous position sucking the pistons back in. I assumed it created a vacuum where your pedal created hydraulic force to move the pistons out but it became a closed system so there was no more fluid to fill the void. I am sure someone will chime in with the appropriate terms and proper explanation.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-08-2010, 04:26 PM
You're correct.
It's called a "vent" for that purpose - route for atmospheric pressure.
Sherwood
Old 03-08-2010, 04:58 PM
This problem can be minimized by running a lower level in the reservoir. I run mine about 1/2 inch below the top. I only drain about 1 oz out per weekend.
-Andy
Old 03-08-2010, 07:35 PM
Wilhelm's Avatar
-Andy
+1 on that. On my car (71 911S) after about 30 or 40 miles of really quick canyon driving , I only get a spot on my garage floor about the size of a quarter. My brake fluid level is normally around 1/2 to 1 in from the top of the resevoir. I have no catch tank. Just a clear tube run through a convenient small hole in the bottom of the pan. I check the fluid every couple weeks. It doesnt seem to be a big issue.
I suppose for full-on track driving, lots of laps, G's, heat, etc. I would need something better.
Old 03-08-2010, 09:42 PM
Black and Blue
Kemo's Avatar
anyone make a vented cap? Combine that with lower level of fluid?
Kemo
Old 03-09-2010, 07:34 AM
That could be easily accomplished with a small drill (remove cap first).
Can't think of any dire consequences other than the purists wanting to know about the missing plastic.
Sherwood
Old 03-09-2010, 09:52 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Sherwood
Not necessary, just use the standard vent with hose routed to the floor for street cars and to a catch tank for track cars. For both run the fluid (cold) down a 1/2" or so. Done.
Gary R.
Old 03-09-2010, 10:04 AM
I just did what Sherwood suggested, drilled a small hole in the cap and clamped the overflow tube. Great brakes and no fluid loss and no catch can to empty. Confirmed over a 3 day DE at Watkins Glen.
1986 3.2 to 3.4 conversion
Old 05-20-2012, 06:58 PM
Walt Fricke's Avatar
Anyone gotten further in analysis of this issue?
My SC started life as a '77 2.7, with no vacuum assist brakes. I upgraded with SC flares and a 3.0. I DE's and once raced with slicks, now with Hoosiers. I get around a track fairly well, so am pulling whatever Gs are normal in a pretty fully prepped track car of this type.
Then I added the power assist brakes without changing anything else. And I started having this issue. I have to watch the fluid level carefully, and installed a catch bottle to keep from spitting so much out the front.
So my suspicions rest on some difference in operation of the power assist MC. I doubt my MC itself is bad, as it was new and others seem to have this issue. Has anyone with an old style, non-power assist MC had this problem?
Could the fact that the non-power reservoir is so far away and above the MC have an influence on this?
I share the belief that high quality brake fluid does not expand enough to push fluid out of the reservoir. But I don't have the expansion coefficients to hand to quantify this. And if it was expansion which did it, when the fluid reached equilibrium it ought not to expand further, in which case the outflow should stop. Not the case for me.
I wonder if reorienting the reservoir so the breather faced rearward would solve this? When I had some instrumentation 20 years ago, I would see maybe 0.33G accel, but about one G lateral and decel. Anyone tried this?
I run stainless pistons, titanium plates behind the pads (after they have worn a bit so they can fit), have ducting (yes, not always in the best shape) from front spoiler openings, and the right setup at the brakes. None of this has changed in years. And, as to excessive heat, with the right fluid the fluid does not boil because the pedal, while it might get a hair lower, does not go soft or cause operational problems, even after a one hour enduro. Had to do all this stuff when wife and I both drove back to back run groups racing and first had pedal go to floor.
I have changed from Castrol SRF (dry boil about 600F) to Prospeed RS683 (683 dry boil). So I suppose I could be putting more heat into the brakes before boilding. If expansion is a factor, that might make a difference.
But for now I am focusing on what I see as the two variables: distance and location of the reservoir, and possible differences in how power assist MCs work.
I have some trouble thinking that the power assist system leaves a fraction of time in which there is pressure in the brake lines/mc chambers, but one or both orfices to the reservoir are already a bit open. In addition, that does not seem to explain why, after enough has escaped to the catch bottle, more keeps coming.
Any further thoughts on this?
Old 08-17-2012, 02:12 PM
