Wash. State
nesslar's Avatar
Does the AC compressor bracket bolt in place down below?
I removed the compressor, rear condenser, and mounting clips on my '86, covered up the hose and compressor openings.....told my Wife, "No, Dear, I'm not going to just leave the stuff 'lying around'....".
Looking at the mounting bracket for the compressor, there is a long curved part that goes down to left. I can't tell, and lazily, didn't jack the car up; does it bolt in down there, or just up top? Thanks.
Old 03-01-2010, 08:14 AM
Somatic Negative Optimist
Gunter's Avatar
Lift the rear safely, go under there, have a look-see and you'll be rewarded.
Removing the bracket is a little tricky because the tin-ware is somewhat in the way.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-01-2010, 08:25 AM
Wash. State
nesslar's Avatar
Thanks. Just found the "look" on a diagram....
Old 03-01-2010, 08:26 AM
gtc gtc is offline
abides.
gtc's Avatar
It's easiest if you remove the muffler. I'm not sure if it's even possible otherwise.
The bracket bolts to the engine carrier, just below the tin.
Graham
1984 Carrera Targa
Old 03-01-2010, 10:31 AM
Recreational User
porschenut's Avatar
Yes, I did this a couple years ago. You'll need to remove the muffler and even then it's a little bit of a struggle to get at.
Old 03-01-2010, 11:17 AM
Stibbich 6:11.13
Forza's Avatar
Removal difficulty depends upon the model year, I think. I easily removed the factory compressor bracket on my '83 SC last week without touching the muffler or anything else. Yanked all the hoses and the receiver/dryer in the front left wheel well earlier today. Now just the front condensor and evaporator remain....
Cheers!
John B. Ellis
1983 911SC Coupe
1996 Jeep Cherokee Sport
Old 03-28-2010, 08:37 PM
