asking the experts
Car : 1971 E MFI pertronic ignition and msi
Problem : Very rich, Lots oil in air box, Lots of smoke with throttle, overall sounds like crap. Smoke , smoke and more smoke. Driveable just not enjoyable. Idles ok now with pertronic. Had bad points. Oil over the top of engine because so much going in air box. Oil all over the back of car every time I drive. Need to wipe off layer in short 10 min drive. What has been done in last few months : Rings, Valve Job and seals. Main and rod bearings. Hydrolic tensioners. Dealership did the tensioners and cam timing. Been to several other shops. Little better everytime goes in new shop but not in relationship to the bill ![]() Getting ready to go back to new shop. Thoughts from the board? Gas smell from oil. Oil level correct middle of marks when running and hot. Did searches and not finding diagnosis with what i have allready done.
Don Yount (Texas) 1968 911s/r rally car 1971 911e 1971 Norton Cafe Racer 2007 Elan DP02 American Lemans Lites |
just me
I'm not an expert, and I am sure you tried it already.
drain some of the oil and see if it still happens?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Thanks but tried. It was very thin like mixed with fuel. Did before went on a long drive. Didnt seem to change any. Made it home with fouled plug.
Stop driving it. Do not run the engine until this is fixed otherwise you will ruin the bearings from fuel dilution.
Two main potential issues here: 1) Fuel is mixing with the oil inside the MFI pump. Was that overhauled? 2) Rings have not seated, thus oil may be pumping past them. Have a leakdown test done immediately to confirm. Where in Texas are you? Mayo Performance in the DFW area is very good with these cars.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
MFI pump not overhauled. Mayo was next shop to go to... This week hopefully has opening. Change mfi belt twice thinking it was slipping.
Air meter reads 14.9
Talked to the engine builder. Says rings should have set by now. 400-500 miles. Will update thread after mayos for future searches and research.
Any other last minute suggestions? Long drive to mayos tomorrow.
Max Sluiter
Fuel in the oil is very bad. I had that with Castrol GTX 20W50 and switched to Brad Penn 20W50 and now the oil stays nice and clean. I think the Castrol broke down too easily and got thinner, getting mixed in the MFI pump.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Don
Don't drive it to Mayo's, have it towed there.
Scott '78 SC mit Sportomatic - Sold |
if you have to drive it, do an oil and filter change first. it usually takes a while to fuel foul it. my guess is it's running super rich.
Super , super rich. Mayo cant get me in to 12th. Will let everyone know after that for futher searches.
is the heat hose attached between the pump thermostat and the left heat exchanger? will run way rich if the t/stat doesn't get warmed.
yes. have to lean toward the mfi pump not working properly. Every thing else new. Too many mechanics have have had their hands in it lately. Wish i could get good advice, most mechanics just want to bad mouth the guy ahead of them. I just want it fixed. Mayo booked up so will have to wait....
Will post a few pics in the mean time while i wait to get into the shop. Maybe something glarring that will be noticed.
Don,
Ed Mayo will be able to solve this. Follow Steve Werner’s and John Walker’s admonitions. Do not drive there without replacing the engine oil and filter! In fact, do not start the engine without a fresh oil change. If the drive is long and you gain oil level … STOP and change oil again. A nice flat-bed tow is best. I agree about trying to find an immediate cause. As noted, the first suspect is a disconnected or blocked (mouse?) hot-air hose from the left heat exchanger to the thermostat. When driving for a while, the thermostat should be too hot to touch. One thing Ed will have to deal with is your oil/gas contaminated muffler. It will take some long highway time to burn out the oil. It is also possible to have it cleaned in a radiator shop if it is not an ‘aluminized’ version. Ed may send you home with a ‘loaner’ clean muffler as it is difficult to set the mixture with a very contaminated muffler. Once the immediate problem is solved, have Ed do the CMA. While running perfectly at home, you repeat the C&M part of CMA. This will establish a good ‘baseline’ for you to diagnose future issues yourself. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
