Please identify this line
Can anybody please let me know what this approx. 1/4" welded male line is for? Car is an 82 SC and the braided line that was on here has disintegrated. Thanks in advance.
Old 03-18-2010, 02:47 PM
Recreational User
porschenut's Avatar
I'll take a stab and guess it's the hydraulic brake line. The one on the bottom looks like a clutch cable and I don't see any others that look like a brake line. Is there any brake fluid in the car? Are the rear brake lines connected to anything?
Old 03-18-2010, 03:38 PM
group911@aol.co's Avatar
If it had a braided cloth line on it, it should be the vacuum line for the power brakes.
Thanks,
Bob
group911@aol.com
Old 03-18-2010, 04:06 PM
sjf911's Avatar
Brake booster is the large line just below that. That should be the fuel tank vapor recovery line to the charcoal canister.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-18-2010, 04:10 PM
Recreational User
porschenut's Avatar
Power brakes on a 82 SC?
Old 03-18-2010, 06:49 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
i think its the vacume source for the center option heater controls, the larger line to the left of that is the power booster line.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 03-18-2010, 07:16 PM
Almost Banned Once
sc_rufctr's Avatar
It's not power brakes... You can see that line curving to the left under the line in question.
I just looked on my car and there's nothing there on my 78...
I'm guessing it's something to do with providing a light vacuum to the charcoal canister in the luggage compartment. (If you have one)
Were does the other end go? Can you trace it back to the air box?
- Peter
Old 03-18-2010, 07:17 PM
Really?
Thanks,
Bob
group911@aol.com
Old 03-18-2010, 09:16 PM
Well, it has a vacuum booster but that's not the same as power assist. Power brakes didn't show up until the 964. I realize you were talking about the vacuum line from the booster unit.
So technically, only the c-4 has power brakes?
Thanks,
Bob
group911@aol.com
Old 03-19-2010, 07:40 AM
brads911sc's Avatar
My 83 has power brakes. otherwise it would feel like trying to stop a Mack Truck. I suppose if you are really going to split hairs... its vacuum boosted/assisted brakes not power... but are really going to go there?
On my 83, that line in your pic attached to the charcoal canister in the rear and was for Fuel Venting. My charcoal went away with my PMO ITB install so I have nothing on that line now.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-19-2010, 07:57 AM
Thanks for the replies.It is the charcoal / vent line I believe.
Old 03-22-2010, 12:14 PM
