2002 996 C4S
Transmission problem - kicks out of 1st
Hello all -
After a great drive from New York to Maryland and back a few weeks ago, my '84 911 Targa decided to start kicking the transmission out of 1st gear after about 2 seconds from every start. I was able to hobble home in 2nd gear with no other issues and started to investigate a bit. I spent some time this weekend adjusting the shift coupling - HOPING this was the problem - but after various adjustments, it clearly is not. What's next? From what I have read, I may need a transmission rebuild. Money is extremely tight right now - so I hesitate to take the car in somewhere and end up with a $3000 (or more?) bill. While I don't have the time / know how to rebuild the transmission myself (even with some of the great guides out there), i would consider having some friends help me pull it out (along with the engine) and send it for a rebuild. Any suggestions / options are appreciated. Would also be interested in hearing expected costs for the various options. Hoping to have my car on the road this year - but it may not be possible at this point. ![]() jcsjcs
jcsjcs Have: '02 996 C4S Had: '87 944, '84 911 Carrera Targa |
French Import
Before you take the engine/transmission out of the car check out this thread.
Hopefully this is your issue and all is well.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
if you can hold it in gear by keeping pressure into 1st gear, its syncro's.
Good luck. My tranny is in the shop this very moment for the very same issue. I pulled the access plate and found nasty small bits. Cross your fingers, it could be adjustment on the coupler.
Good luck! Larry |
Dropping the engine is a $400 labor cost, which you will save if you do it yourself. in this case, if the tranny just requires a 1/2 synchro repair, then it is $750. If it requires a more extensive refresh, then $2000 is more likely.
I don't recommend just a 1/2 synchro repair, but I do understand that money is tight. Good luck with this.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Im having the exact same issue. Was planning to drop the tranny this weekend. Please let us know what you find and I will let you know what I find.
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
It's likely the 1st gear synchro hub. AND if you replace that you should replace the slider...as well as the 2nd gear synchro hub too.
Could be the coupler, but once it's in gear, it's in gear. worn dog teeth is what causes this. I just did all mine and yes, $2000 is very much the case (and I did everything myself).
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) |
2002 996 C4S
I appreciate all the feedback.
I am going to give John Walker a call tomorrow to get his input and suggestions on how to proceed. I will plan to open up the access plate soon to see what i am up against. I promise to post pics. Anyone know of a good transmission rebuild shop on the east coast? I am also going to look through Excellence to review some options. I recall seeing some rebuilt transmissions for sale. Is that a viable option? Buy a rebuilt and sell my core?
if I have no problems with my tranny other than the current problem I'd rather fix mine that go with an unknown tranny, even if rebuilt. Give Taso at TKX Performance a call, he does very good work with 915's.
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
Peter Zimmermann, the author of the book, "The Used 911 Story" has a great 915 tutorial going. Check it out, it's a great read on the rebuilding of the 915 gearbox.
Porsche Wiki |
Keep the Shiny Side UP! Pete Z. |
2002 996 C4S
I just took a look at Peter's tutorial - need to read it in depth over the next few days. I really appreciate the section that discusses part costs and basically debunks the feasibility of a $1500 rebuild. I can just hear whatever mechanic I choose telling me that there is more damage than initially expected and so the cost is now $2500, then $3500, and so on.
I have to say that those pictures make the transmission look quite beautiful - something about gears that makes me weak in the knees. So it seems that if I take on this project myself - i have a bit of work and learning cut out for me. And possibly up to $3500 in parts - any estimates on tools required? I will review Peter's tutorials and create a consolidated list (unless there is already on that I missed.) AND if I have the engine out, probably best to rebuild the clutch too..... So if the car is off the road anyway - and since I can't afford to have it done in a shop right now - why not take a few months (or more) to do the job myself.... HMMMM more to come on this saga....
jcsjcs; how many miles are on your car/transmission? Has the car ever been used for sporting purpose, or mostly street driving?
If you do indeed need some work, I have heard good things about Gary Fairbanks.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
2002 996 C4S
My car has 102k on it. I am the third owner - so I am not sure about its history. My understanding is that the last owner only used it on the street.
I have participated in about 5 AutoX - and plan more when it is back on the road. The shift coupling was horribly out of adjustment when i got the car. I did not know what to expect and thought it was typical. The PPI should have caught that - but in hindsight they overlooked a number of issues. I changed to Swepco & adjusted the shift coupling & installed a Seine Shift Gate - and the transmission has been pretty good for the past 6 months. No issues on my recent trip - but when I got off the highway in NY, it started the kicking out of 1st. So if I embark on this project, do I open it up and then determine ALL the parts I need to replace? I won't be in any rush to complete the job - but its an interesting way to work - and will be interesting from a budgeting perspective.
With only 100K miles it's very possible that you can get away with fixing just the 1st and 2nd synchros. Your next step in the process is to drain the trans oil and see what's stuck on the drain plug magnet.
2002 996 C4S
Thanks, Peter - that's encouraging! Will let you all know what i find.
Red Line Service
jcsjcs, I assume from your signature your on the East coast? At Red Line we have a professional bore scope and through the drain plug, fill plug , or the fixed fork access plate can look inside the trans at the syncros, dog teeth, sliders , etc., and take actual photos of these items to show the customer. Perhaps there is a shop in your area that has this type of equipment for diagnosis. The teeth for 1st gear are asymmetrical and look different then the teeth for 2nd - 5th, those teeth all look the same so although you cant inspect bearings in this manner, you can look at the other wear items. Draining the oil, performing this inspection and refilling the trans should take about 1-1 1/2 hours.Good luck with your repair.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
My vw dune buggy was doing the same thing in first.
It turned out to be a broken front tranny mount. The tranny was doing a wheelie inside the car, and pulling on the shift linkage causing it to pop out of gear. Another buddy had loose engine bolts causing teh same problem when teh clutch was first engaged from a stop. |
| Tags |
| 915 transmission rebuild |
