Wouldn't have believed it....
Wouldn't have believed it if I hadn't done it myself, but changed over from Valvoline 15-40 to Mobile 1 15-50 thinking all that Syn Oil "will cause leaks" was just nonsense. I wanted to use a more modern oil (and the same as my wife's Mercedes). Well I had a totally dry (no leaks) engine, but sure enough my motor started leaking. Only slightly, but still it's a leak and very unwanted. I then re-read the oil bible, and it's quite a brain freezer for a non scientist, but decided to use Swepco 306 15-40. It seemed to be well recommended.
So I suppose hoping to see no more leaks is too much to ask, but will hope for the best. So.... seems like synthetic WILL indeed end up on your garage floor!
Old 03-02-2010, 12:41 PM
PS This was in my 86 3.2 by the way.
Old 03-02-2010, 12:43 PM
As a fellow '86 owner, wanted to throw out that I switched to synthetic after my 3.2's top end rebuild break-in was complete. So far, around 45k miles later, zero drips on my garage floor. I believe that fresh seals/gaskets are the key here.
Old 03-02-2010, 12:58 PM
Absolutely right, Sir,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-02-2010, 01:02 PM
So... Just so I understand. even though I had a total dry engine, ( I checked all the time) in order to use Synthetic I would have had to upgrade seals and gaskets?.
Old 03-02-2010, 01:31 PM
Tim
Send a message via MSN to tvanbroekhoven
My SC has old gaskets. I filled her up with Castrol Edge Sport 10W60.
No leaks !
Old 03-02-2010, 02:01 PM
Southern Class & Sass
Dixie's Avatar
Keep in mind that modern oil and cars with flat tappet cams, like an old 911, do not get along. l'lI leave you to do a search if you wish to know more. There's a plethora of info on the forum regarding this topic.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 03-02-2010, 02:10 PM
My recollection is that conventional oil causes seals to swell over time but that synthetic oil doesn't. Thus, switching to synthetic can cause the seals' swelling to dissipate and the potential oil leak that was otherwise contained by the previously swelled seal to turn into a puddle on your floor.
Old 03-02-2010, 02:13 PM
Wash. State
nesslar's Avatar
Well....I had to dig this thread up, because I have been topping up with "old dinosaurs" of late (as in for months), as opposed to returning to synthetic (drained years ago) which was followed by "The Green Oil" for quite some while.....now, recently, no leak, though previously it wasn't very much at all. Hmmmm.......I do like it. '86 3.2.
Old 03-09-2010, 02:35 PM
dshepp806's Avatar
You are right Darren,...you can't blame the oil, at all. Get the seals and gaskets in order,..and you've a dry engine with synthetic............simple.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-09-2010, 04:14 PM
End of experiment, for me.
As I said in my original post, this is what I know for sure. With 15/50 Mobile ! my '86 it would leak a few drops on my garage floor. Not a puddle, just a few drops (after a good warming up). So I changed to Swepco 15/40 a while back and after a good long drive to get operating temp there was no evidence of any leaks on the garage floor. Tried this twice so as to be sure. Both times the engine was up to full temp and it stayed dry. So,.. I'm not trying to start trouble but these are the facts in this particular instance. From here on in it's swepco for me! PS My engine has 99,000 miles and to my knowledge had no evidence of leaking until I used Synthetic oil.
Old 03-10-2010, 09:03 AM
Wash. State
nesslar's Avatar
Exactly why I resurrected the thread, since my recent experience mirrors your's, though different brand oil, also 15W/40. The PO had Mobil 1 in it, I had switched to BP a couple+ years ago when I changed the oil. I can see that new seals and gaskets ought to fix ANY leak assuming the associated part/pieces are sound, but I am simply happy to have found that this has occurred, as I'm sure you are; beats tearing things apart! Like you (and the others I'm sure), no intention to be argumentative or anything of the sort, "just the (happy) facts". Though also an '86, my car has only 66K on it, with no record of "long" sitting/storage time....but difficult to say for sure.
Old 03-10-2010, 09:28 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
We have used Mobil 1 30, then 15-50 for decades on our '86, as in all of our cars.
Sure, we had leaks, from the breather tube (replaced), oil pressure sender gasket (replaced), one cam line (replaced).
However, with our front oil cooler fan thermostat set @ 210F (on), and 200F (off), we very rarely see temps over 210F.
Your decision should serve you well.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-10-2010, 09:44 AM
