| Registered Join Date: Oct 2007 Location: Rye, New Hampshire
				Dropping the motor question
			I'm going to be dropping the motor & tranny soon in my SC to do some transmission/clutch work.    I'm a first timer. I'm meeting with a buddy this weekend to see how he does it, although he told me he "balances" the motor when he lowers it out. I saw harbor freight has some motorcycle lifts ... is that something that would work? What are some of the methods you guys use? I'm all ears... Thanks Dan
				__________________ 1979 Porsche 911 Black on Black widebody 3.2 - SOLD 2015 Jeep Wrangler Sport Unlimited - White 1984 Porsche 928s Black on Black - SOLD | ||
|  03-09-2010, 11:32 AM |
| Registered |
			Yep, the motorcycle lift works great. make sure you use some 2X12 pieces of wood.
|  03-09-2010, 11:45 AM |
| Registered Join Date: Oct 2004
			supporting engine at removal Engine Drop Tips? Engine drop,finally done All I can add is to use 6-ton jackstands or larger, especially at the rear torsion bar. Last edited by rusnak; 03-09-2010 at 12:06 PM.. | ||
|  03-09-2010, 11:52 AM |
| Registered |
				engine drop
			follow the pelican 10 easy steps and it is Be Careful with the plugins on the side and back of the engine good luck   | ||
|  03-09-2010, 12:03 PM |
| Registered Join Date: Jan 2005 Location: Las Vegas
			There are hundreds of threads on this topic.  Do a search and you can quickly find the best practices.  After doing this several times on my '86 and '87 I strongly recommend you remove the rear bumper.  This makes it much easier to get the engine clear of the body without having to jack the car four feet off the ground.  Much safer and gives you the opportunity to clean bumper and bellows. Good luck Randy
				__________________ 1986 Carrera Targa - sold 1987 Carrera Coupe - sold 2003 Twin Turbo - sold 964 Coupe - on the hunt | ||
|  03-09-2010, 04:39 PM |
| Registered |
			+1 on the bumper removal. You don't have to tilt the car so badly and it is more leveled for getting the shift rod back in the tunnel. As for the Harbor Freight motorcycle jack: I works well although it is a bit short. We ended up adding two 2x4s and a furniture dolly. The 2x4s will help you to put the engine a bit more forward on the jack. You will need this space otherwise you will not get the exhaust past the jack's hydraulic bottle. (see picture) Apart from that it worked like a charm.
				__________________ 1981 Pac blue SC 3.2L | ||
|  03-09-2010, 04:47 PM |
| Registered Join Date: Oct 2001 Location: San Carlos, CA US
			your 79sc has a flat oil drain plate where you can balance the engine with a jack. No need for a motorcycle jack. drop it on top of 2 small furniture dollies and  you can roll it around the floor. Remove the bumper and you will clear the engine fairly easily.  Good luck.
				__________________ Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 | ||
|  03-09-2010, 05:47 PM |
