Twin plug wires
I have upgraded my 79 - 930 ignition to a twin plug crank fire. During the motor build, my mechanic install an ok set of wires to get everything running. Since then I have started to upgrade the fuel injectors, injector blocks - etc. My question is what do you guys recommend for the spark plug wires? Clewett, Magnecor or any others. I need at least a 8.0mm wire. Just wondering what your experiences have been.
Old 03-16-2010, 02:05 PM
I would rather be driving
jpnovak's Avatar
I bought a roll of bulk silicone, spiral core wire from Summit Racing and used the early style "woodscrew" Beru connectors to make my own. The process was easy and I was able to route them in a way that was easy to work with. This can be important if you have a crowded engine bay.
Old 03-16-2010, 03:07 PM
Grady Clay's Avatar
Yes, 8 mm wires.
A common mistake is to run all the wires parallel.
This looks pretty but can induce cross-fire.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-16-2010, 03:28 PM
