Jupiter 911
bklyn's Avatar
Acceleration pop question.
Recently, upon giving the engine any revs the engine will pop. Not loud like a back fire but noticeable, it only happens when not in gear. I have replaced wires,rotor,cap,plugs and rechecked them all. Any ideas? thanks
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 03-19-2010, 08:33 AM
muck-raker
kidrock's Avatar
Does it "pop" during acceleration, or after your foot is off the gas?
I can think of 3 possibilities:
1) running rich,
2) exhaust leak, or
3) possible broken head stud(s).
Hopefully, it won't be Bachelor #3.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 03-19-2010, 04:13 PM
efhughes3's Avatar
I'd look at a vacuum leak-intake maybe.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 03-19-2010, 07:00 PM
Jupiter 911
bklyn's Avatar
The pop will happen after my foot comes off the accelerator, I also hope it is not a head stud. The engine had a complete rebuild (including studs) approx. 22k ago.
Old 03-23-2010, 08:44 AM
That happened to me. It was a chain tensioner, not tensioning...
1970 911 T Targa
Old 03-23-2010, 12:29 PM
muck-raker
kidrock's Avatar
from the description of your symptoms, I would recommend checking for vacuum leak first. If that checks out OK, then I would move to checking my air/fuel mix.
STONE
Old 03-23-2010, 03:24 PM
Jupiter 911
bklyn's Avatar
Looked for a vacuum leak but had no luck, so I decided to remove my much loved SW chip just as a hunch when kidrock mentioned air/fuel mixture and replaced it with the oem. Went for a 20 min. drive and so far so good. Was this the problem? what to you guys think?
Old 03-23-2010, 04:37 PM
efhughes3's Avatar
Call Steve; that seems like the best route.
Old 03-23-2010, 06:33 PM
