Recommended Setup for Engine Drop
I have wanted a 911 for about 30 years now and am finally at the point where I might be able to afford a project.
I have rebuilt many non-Porsche engines in my life, but they were all the type that can be pulled with a cherry picker. I don't currently have a lift, but will factor that into the overall budget. Can I get some recommendations on what I would need for a lift and rolling scissor table (or whatever you recommend) to drop an engine?
Tron
Old 03-19-2010, 08:46 AM
Tom '74 911's Avatar
Tron -
While a lift is nice, it is not necessary. The first 3+ times I dropped my engine I used (1) floor jack, some jackstands and some blocks of wood under the jackstands to get the rear high enough in the air to slide the motor out once it was on the ground. It's pretty simple actually. If you have a cherry picker, you could use it to help raise the rear end too.
Good luck w/your project!
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 03-19-2010, 08:51 AM
signature65's Avatar
Second what Tom says.....I dropped mine with a floor jack too. Made an engine dolly with some plywood and castors. Its really very simple to drop these engines.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 03-19-2010, 08:53 AM
GaryR's Avatar
Send a message via ICQ to GaryR
While you can do it w/o a lift, a proper two post lift will make your life SO much easier if you have the $ and room for it. I use an 4 wheel ATV jack (Sears?) and simply lower the lift to put the engine weight on it, unbolt, and lift the car while slowly working the engine back to clear the transmission rod from the tunnel and then up she goes leaving the engine/transmission on a rolling platform.
Gary R.
Old 03-19-2010, 08:59 AM
Hilbilly Deluxe
emcon5's Avatar
Lets set the wayback machine to December of 2001:
Engine drop question
82 911SC Coupe
GTI Cup #43
Old 03-19-2010, 09:48 AM
Less brakes, more gas!
euro911sc's Avatar
LOL
no lift here either... I do run the front up on ramps so the car angle is not very steep. I also have several 2x12x16 planks I put under the 6ton stands of the rear... its cake...
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-19-2010, 09:53 AM
Somatic Negative Optimist
Gunter's Avatar
This subject has been covered ad nauseum at least once a week for many years and many, many posts are available.
Use the search button on top for "engine drop" and you'll be rewarded.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-19-2010, 11:15 AM
