Protective coating for factory oil tank?
I have an NOS oil tank to install on my car. Any recommendations of products to protect the exterior from corrosion? Thanks for any helpful ideas
Mark
Old 03-18-2010, 06:23 AM
Recreational User
porschenut's Avatar
All the oil tanks I've seen are either nickel-plated copper or stainless steel. The only protection needed should be paint, AFAIK.
Old 03-18-2010, 08:51 AM
Somatic Negative Optimist
Gunter's Avatar
Maybe a rust paint like Tremclad or Rustoleum but I'd also use a chip-paint that is used on some front valances.
The rear wheels kick up a lot of gravel and I even use roof-tar on the side that faces the Wheel.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-18-2010, 09:23 AM
AutoBahned
RWebb's Avatar
powder coating is highly chip resistant
some tanks have a little rock guard grill on them - my 73.5 does
Old 03-18-2010, 02:15 PM
Senior Advisor
James Brown's Avatar
If it's not steel, how can it rust?
08 Cayenne Turbo
Old 03-18-2010, 03:21 PM
304065's Avatar
The steel tanks were copper plated, not solid copper. They can and do rust, particularly at the top of the tank where dirt accumulates over time. The dirt attracts moisture which rusts holes in the tank.
A stainless oil tank would either be an aftermarket piece, or something from the racing department. Highly unlikely that the NOS tank is stainless- most likely copper-plated steel.
A few coats of gloss black epoxy should do it-- unlike powdercoating you can easily remove it when it gets chipped every decade or so and re-do it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-18-2010, 03:25 PM
Retired Member
Brian 162's Avatar
I used high temp. dupli-colour paint 2 years ago. The paint hasn't come off yet.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 03-18-2010, 06:00 PM
To build on what John said, the best thing you can do to prevent rust is to keep dirt and crud from lodging in tight places. In some climates trapped dirt will never dry out. You have probably seen cars with areas of no paint that seem to have surface rust but never perforate. Car generally rust out from the inside where water is trapped either by part of the car (lower windshield corners etc), dirt buildup (wheel wells) or carpets/sound mats. First try to keep water out by maintaining seals and so forth. second, regularly blow out any areas that tend to accumulate dirt. I realize this is a bit beyond the scope of the question but it's basic to preservation. Just to be safe I would coat the tank with POR-15 or find a powder coater who can apply nylon.
regards,
Phil
Old 03-18-2010, 08:49 PM
BoxsterGT's Avatar
How about the Rhino liner stuff or similar used for truck beds?
Pretty stone-proof I would think.
Len
Old 03-19-2010, 05:39 AM
Len
Thats what I've been thinking. Hopfully it can be applied right over the factory black exterior paint.
Thanks to all for ideas
Mark
Old 03-19-2010, 05:56 AM
POR-15 with the same companys chassis black as a top coat. It will never rust and is very duable against stone chips.
John
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 03-19-2010, 07:26 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Powder coat is pretty nice if you think it is worth the trouble. It is overkill and other ideas above will work fine. However, it is relatively cheap and you wont have to get your tank dipped to clean out the oil before the coating is baked on.
Old 03-19-2010, 01:46 PM
I second POR-15. It bonds to the metal along with any rust present, would be fast, probably cost the least, and cures like powder coating. A half pint would be more than enough, so if you had any other small parts you wanted to treat, you could use up the remaining amount on them.
Marv Evans
'69 911E
Old 03-19-2010, 01:55 PM
Just a note. A source I have, Porsche 911 by Lindsay Porter and Peter Morgan states: "September 1971...Dry sump oil tank now made of stainless steel." (p.243)
"October 1972...External oil filler flap deleted for 1973 model-year oil tank (now of stainless steel)..."(p.244)
Don't know how accurate that is. I have a 73.5 and the tank looks to be copper clad. Does anyone have a definitive answer?
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-19-2010, 05:49 PM
AutoBahned
RWebb's Avatar
my '73/5 tank is copper clad - w/o question
Old 03-20-2010, 10:05 PM
al lkosmal's Avatar
My 71 is copper clad. I coated it with POR-15.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 03-20-2010, 10:47 PM
oil tank resto
Hi- I am restoring a '79 SC and on the oil tank I splurged & had a radiator shop boil it out ($80). Then painted with good anti rust black paint, then a good undercoat like 3M rubberized undercoating in spray can. Prior to re-paint many small corrosion spots needed removing/digging out. I was surprised I didn't find a pinhole leak.
PB
Old 03-21-2010, 01:42 PM
