How to Identifying Turbo Tie Rods
Hi I have been lurking here for years but never introduced myself (or car). 89' Carrera I have had it about 5 years. Has about 80k and burns no oil. I do about 2 DE's a year, but hoping to increase that. Here are a couple pics:
chip.
I am am trying to spend a little (around $500) on the suspension. It is stock except for a cat bypass and SW chip. Trying to get rid of some of the body roll.
I am not sure if it has turbo tie rods, is there an easy way to check?
If it doesn't should I spend the money on them or take a different route first? Like lighter wheels?
Any suggestions appreciated.
Dave Hunter
1989 911 3.2
Old 03-22-2010, 07:30 AM
Dave,
Thats a drop-dead gorgeous car.
JMHO, but if you want a noticable and useful reduction in body roll, you need to revise your budget upward somewhat. You won't get anything worthwhile for $500.
You can ID turbo tie-rods (they didn't come with them) by looking for the longer rubber boot that covers the inner monoball or observe the two-piece tie-rod itself. Stock ones are 3-piece ones (inner U-joint, adjusting sleeve, and outer) and look for the inner "U-joint" coupling them to the steering rack.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-22-2010, 08:30 AM
What's Facebook?
turborat's Avatar
Dave,
Nice Carrera. One of my favorite 911 colors.
IMHO - One cannot get much done on the suspension of these 911s for $500. Its a slippery slope that can cost many thousands. Bigger torsion bars are a good start to get body roll under control (about $500 - $800 for parts).
Then the shocks will need to be re-valved to match the new springs rates. Then there's adjustable sway bars to consider. Coil-over helper springs when torsion bar limits are reached, solid suspension bushings, track wheels and tires, track set-up, a trailer to haul the car to the track, a truck to pull the trailer, lightening the car because its no longer a street car. ......sorry Dave, that's my slippery slope.
The question was tie rods. The factory ties rods have a large fork at the rack end and allow the rod to move up and down only. The turbo rod ends are more like a ball joint and articulate in all directions. They are cheap enough that I would consider replacing them when you have a need for other work that will require a wheel alignment.
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 03-22-2010, 11:09 AM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
Check if yours look like this:
Take care.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 03-22-2010, 11:43 AM
ASD ASD is offline
ASD's Avatar
what about a strut brace? Worth adding?
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 03-22-2010, 01:11 PM
The first thing I did to my SC years ago was a strut brace. Benefits = low cost and easy installation. I'm not sure there was a noticable difference- but all the cars seem to have them.
Next were adjustable sway bars. Cost of the pieces were managable and installation was not to expensive. Later I did the torsion bars. You need to factor in with torsion bars that the car will have to be corner balanced and aligned afterwords since the suspension is taken apart. While a change in torsion bars is the best way to manage body roll, the overall ride can get pretty harsh.
I decided to compromise but using the sway bars to manage body roll without getting a harsh ride. My $.02.
Bob D
1982 RoW Silver 911SC - PCA E #339
1997 993 Turquoise Blue Carrera S
Old 03-22-2010, 01:49 PM
Platinum Member
dad911's Avatar
Originally Posted by dyhunter View Post
Hi I have been lurking here for years but never introduced myself (or car). 89' Carrera I have had it about 5 years. Has about 80k and burns no oil. I do about 2 DE's a year, but hoping to increase that. .......
IMHO Best $500 improvement would be to spend it on registration for more events.
Don't piecemeal the suspension. Save up a few grand, and freshen the whole thing, bushings/sways/struts.
Old 03-22-2010, 02:59 PM
True wisdom!!
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-22-2010, 03:54 PM
Thanks for all the replies.
So should I replace the tie rods with turbo tie rods? What are the sign of worn tie rods?
Dave Hunter
1989 911 3.2
Old 03-22-2010, 04:35 PM
What's Facebook?
turborat's Avatar
No need to replace them unless they are bad. The car will require re-alignment and that will add to your cost and inconvenience. Save your money until you do more major suspension work. If they are not bad, you really won't feel any difference with the turbo units with a completely stock suspension and tire size anyway. Of course, its your car and your money...........
Signs of bad tie rods are typically uneven tire wear on one or both tires, loose feel or dead spots when turning the steering wheel and some sort vibrations and wandering at speed. If you decide to replace the tie rods also check your wheel bearings, ball joints and "A" arm bushings. These components wear and may cause similar symptoms
Turborat
2001 330Ci
Old 03-22-2010, 04:52 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
I have to concur now that I have had my suspension overhauled. save up. do the whole nine yards. one piece at a time just adds to the over all cost.
after the work I have had done my 9 is transformed. on rails. you can really feel every corner working. albeit the ride is now a bit harsh, but not unbearable considering the upside.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 03-22-2010, 05:00 PM
rlw rlw is offline
You have gotten excellent advice. I just had turbo tie rods installed on mine. I was already having the car aligned and corner balanced so I was going to have to pay that cost either way. I noticed a small difference with the turbo tie rods, but not huge. If I was not already having the other work done, I would not have done it now. Suspension is what I am saving up for next. Tie rods were only the beginning.
RW
1989 911 Carrera Cabriolet Black
SW Chip, M&K Pre-muffler and 1:1 Muffler
1983 944 Spec project car RIP
Old 03-22-2010, 11:23 PM
Thanks for all the info.
It seems I will be going to a few more DE's this summer,
which is always good.
Dave Hunter
1989 911 3.2
Old 03-23-2010, 08:46 AM
Ruby911
ruby911's Avatar
I cant tell exactly by how you asked your question, but are you suggesting the turbo tie rods will reduce body roll? If so, one has nothing to do with the other.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 03-23-2010, 04:28 PM
I was under the impression that I should replace the tie rods as preventive maintenance. But instead I will keep an eye on them for excessive wear.
I was not thinking the tie rods would reduce roll, but thought it might help overall handling.
Old 03-23-2010, 05:41 PM
