Need Alignment Help
Just got my barn find 73T inspected, ride height set and new tires on the car. Ready for an alignment and tons of fun this summer. This morning I took it to the local Firestone who I've used for a lot for other cars, armed with Wayne's 101 book with the alignment project bookmarked and my 84+ Carrera Bentley manual. We talked about the books, the suspension (all newly rehabed), their Hunter machine has the specs, and I left feeling like it was in good hands.
got it back 2 hours later and have driven around for the past few hours having a great time, but I think the specs can be much better. Here's what they did: Front Camber: -.8 and -.9 Caster: 6.7 and 6.1 (they wrote: caster is not adjustable on the measurement printout) Toe: .15 and .13 Rear Camber: -.4 and -.6 Toe: .1 and .07 Here's what the car has: 19/26 bars front 205/55 SO3's on 7x15 cookie cutters Rear 225/50 SO3's on 7x15 cookie cutters Ride height: LF: 24.5 LR: 24 RF: 24.5 RR: 24 The rear quarter fenderwell lips are ground down and rolled over. The right rear I have contact/scuffing on accelerating through a left turn and in/out of drive inclines. the left is fine. the right rear tire does look like it's coming out of the well more than the left. So here's the net-net: other than the tire contact, the car drives great. Really solid, very planted, especially given the new tires and it's cold today. No, I didn't push it, but it just felt right. I got the "alignment for a lifetime" deal so I can keep bringing it back until they get it right. The Firestone guys were eager to please and if I bring them back specs, they'll set the car up. What specs should I give them? What do I tell them about the front caster? here's the car ![]() here's their printout ![]()
Tru6 Restoration & Design |
Regis turd ab user
Here's my specs on my '71 Targa with 205/60's on 15x7's.
Front Left Right camber -1.26° -1.26° caster 6.47° 6.43° toe 2.8mm 2.8mm Rear camber -1.42° -1.42° toe 1.6mm 1.6mm I'm no wizz on this subject but it is my understanding that there should be more negative camber in the rear than the front and I also can't address your caster question, BTW my suspension is stock, relatively fresh with Bilstein HD front and rear. David |
Southern Class & Sass
I wouldn't worry about changing your front caster setting.
The net: Your caster is good enough.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Regis turd ab user
Shaun, even though the fender ride height measurements are equal, has the car been corner balanced with your equivelant weight in the drivers seat?
David |
Thank you David, I'll bring your specs with me when I go back in.
Rob, thank you for the confirmation on the caster, one less thing to worry about. My friend has scales and we were going to corner balance after the alignment. What do you think?
I'm here to cause trouble
I've got an '86 Cab with 225/45-15's all around... Last alignment was:
Front Left Right camber -1.3° -1.4° caster 5.9° 6.0° toe .1° .1° Rear camber -1.8° -1.8° toe .03° .03° Corner balance, trunk empty, 1/2 tank gas with 175 lbs in the driver's seat: LF: 555 RF: 555 LR: 886 RR: 834 Car w/o driver: 2654 Rack: 1° Ride height: 23 rear, 24 front
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) Last edited by jimbauman; 04-21-2010 at 06:26 PM.. |
