After all the engine and tranny bolts were in and I started putting things back together I realized that I didn't pull the cables that go throgh the firewall (for the speedo & tach?) through to where they are supposed to go
. I also found the wireing cable that gets plugged in teards the front of the engine is being pinched. My question is can I just loosen the engine mounts a little and drop the motor a few inches without having to loosen the tranny mounts? I just need enough room to get those thin cables through to the head of the transmission.Thanks in advance for the help, Michael
-- '87 Diamond Blue Coupe -- '92 Miata -- '06 Scion XB (the wife's) -- '01 Audi S4 (Sold) -- '17 Tesla Model S60 |
Somatic Negative Optimist
No, you need to put a floor jack under the transmission end to lower it enough to free the pinched plug/cable.
Do not lower by the motor mounts, it has no effect on the transmission-end. The small wires going into the tunnel are from the speedo pick-up on the side of the transmission. Also, other small wires from the tunnel are for the reverse light contact on the end of the transmission. And don't forget the ground strap to the body near the mount.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Capitalist and Patriot
Hey Michael,
Glad to see your almost back together! If you need any help hit me up.. Oh +1 on what Gunter said (but I think that is what you meant anyway)
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Thanks for the reply Gunter! If I am readiing this correctly, and please forgive me if I'm not, I just have to drop the transmission end? That would be helpful! I really wasn't looking forward to doing both ends again!
My car is an '87 so the wiring cable at the front left of the engine bay wouldn't be for a CIS but might be for the Motronic. And yes, the reverse light cable is in it's proper place and actually did remember the lower ground strap! Take care, Michael
?Take care, Michael
2 weeks old last Friday!
The Porsche driving suite has been ordered ![]()
However, you'll need to disconnect the coupler in the tunnel!!!!!!!!!! You can only come down a couple inches before the shift-shaft hits the tunnel but, it should be enough to free the pinched cable. Yeah, Speedo and Motronic.
3.4 Bigger is better
MIchael,
You can put a jack under the engine and drop it enough to get the cable out. Have done it. I would also loosen the transmission bolts a coupe of turns so they are not tight when you do it. The other two wires plug into the transmission and don't go into the engine bay.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
