Changing plugs on a 81 SC
Hi
I'm changing the spark plugs on my 81 911 SC and four out of six went well but the two closest to the back on both sides, I can't even get a socket on. Do you have any suggestions? Thank you,
Bucky
Old 03-28-2010, 06:57 AM
Oh Haha's Avatar
if you have the factory installation tool it works great for this task.
This thread has shows other options.
changing spark plugs
Pacific Blue
Wayne
Old 03-28-2010, 07:06 AM
Head416's Avatar
+1 I've heard the factory tool is the way to go, but I don't have one.
I used a socket with two short extensions instead of one long one. First insert the socket with one short extension, then after they're down in the spark plug hole put the other one in. That's the only way I could get it in there. It sucked, and I had problems getting all the tools back out, but in the end it worked.
Aaron
'81 911SC RoW Targa
Old 03-28-2010, 11:26 AM
brads911sc's Avatar
They show up on fleabay. Well worth the $20.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-28-2010, 11:41 AM
John W
I struggled with a socket / extension / universal. Then I discovered I had the factory tool and it was a breeze. The factory tool has flex in it.
John
89 3.2 Targa 123k miles
Old 03-28-2010, 12:23 PM
Somatic Negative Optimist
Gunter's Avatar
Cool
Originally Posted by buckyk View Post
Hi
Bucky
In order to make up the 5" extension needed, I use a 4" plus 1" with a 3/8"-drive ratchet. To make it easier for the plug-socket to slide out after the new plug is in, I put a little Vaseline on the porcelan-portion of the plug.
I think the factory tool is the way to go.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-28-2010, 01:52 PM
arbita1's Avatar
Funny...I did this today as well.
I used the factory tool this time around and it was so much easier. The first time I did it I used a socket/extension/etc. and it took a lot longer.
If you can find one it is a good investment.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-28-2010, 06:17 PM
1974 911 w/ 83 SC engine
Is there at least a link to a picture of the factory spark plug tool? I don't have one either, and need to change my plugs but have been dreading it. Seeing at least what it looks like would give me an idea of what is necessary to get the job done.
Old 03-28-2010, 06:22 PM
Oh Haha's Avatar
Odd spark plug wrench?
Where can I buy a Porsche T-Handle Spark Plug wrench?
Pacific Blue
Wayne
Old 03-28-2010, 07:12 PM
Thanks! Guess I better start trying to find one.
Old 03-28-2010, 07:48 PM
aadrew10's Avatar
A wobbly extension works just as good, and you don't need a universal joint.
- Andrew
81SC
Old 03-28-2010, 10:30 PM
