changing spark plugs
i am changing the plugs on a 1977 911 targa 2.7 . For some reason i cant get the number one plug out, the socket will not go on to the plug, i am useing a 13/16 spark plug socket , i had no trouble at all and this one looks the easist to get to whats the deal anyone run into this problem before thanks
Max Sluiter
Use a metric socket for starters
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Jupiter 911
Hey Pat, I also had a problem, it appeard the socket needed to bend to get in there. After racking my brain I went to the socket that came with the vehicle and low and behold it was flexable. Try that if you still have one in your kit.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
If you have your tool kit, the spark plug wrench Porsche included is the perfect tool for the job.
you dont need a metric socket for starters and thanks guys for the help the socket was in the tool kit and it worked great
Patrick,
Glad to help. BTW... Welcome to what is probablly the best 911 Web Forum on Earth. How about a picture of your car?
+1, the oem tool is perfect. I did my engine last night with the oem tool with the allen wrench it comes with, along with a nice solid 12inch breaker bar that i would slide over the alan wrench to gain additional torque. Once they started to loosen up, i used a ratchet with the same sized hex bit into the oem tool. I did all the plugs in a little over an hour by removing nothing other than the airbox filter and cover.
1984 Porsche Carrera Cabriolet - sold, regrettably 2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably 2005 Mercedes C230 Kompressor Sport Sedan - now... |
Carmagic.us
I don't have the original tools. I'm using a plug socket from the Metrench set, plus 2 short 3/8 extension. Insert the socket with one of the extension first, add the second extension and ratchet.
When the plug is loose remove the second extension, etc. I hope this helps if someone doesn't have the original tools. Cheers
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
i put a swivel adapter on the the socket, then a short extention, perfect length.
(the shotguns)
i don't have a swivel on mine. it's an odd combination of craftsman extensions and it works perfect. can double check if anyone cares.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
