Senior Member
how do i bleed carrera tensioners
I am installing my carrera tensioners into my 78 911. I have seen in various places that I should bleed them first. What I haven't seen is how to bleed them. Thanks
osidak 78 911sc |
Home of the Whopper
I don't think they need to be bled. They have no internal seals so the oil escapes around the piston. Any air would leak out there as well. At least this is my understanding. Hopefully I am right, because I didn't bleed mine!
Have fun! BK |
Yep, you're correct, no bleeding necessary.
Brian Scotti '89 944 Turbo '85 Skater 24 |
Irrationally exuberant
I use leeches.
![]() I never bleed mine. When you "pull the pin" on the tensioner, don't let it snap open. Push down on the piston and release it slowly. I had one fail after changing cams and was told that letting them snap open may have damaged it causing the failure. -Chris |
Senior Member
Doh, looks like I need to keep an eye for mine then as I let them snap a few times when I was doing my cam timing.
So no bleeding required.... Ok I know I had to bleed my tensioner on my MB 240D when I replaced the chain but hey anything to make my life easier. Osidak Thanks again |
Home of the Whopper
I wouldn't use them to do your cam timing! I'd use the old ones. I keep a set around just for cam timing. I'd never use the same set for timing and for my car. I forget why and who told me that, but I prefer to be on the safe side.
-Chris |
