Reg Reg is online now
Reg's Avatar
Door Trigger un-happy
My passenger door's trigger is stuck in the pulled position, rendered useless from the outside.
Has anyone ever taken one apart and fixed this probelm? or am I in for for a 300 dollar new handle?
Thanks for any tips
1970 911 t (sold)
1985 MR2 (sold)
2011 GT 5.0
2007 CRV
Old 12-02-2001, 08:50 AM
Friend of Warren
It's not that hard to take apart. However you have to take your door panel off to do it. The handle trigger is actually a pin that is probably stuck in the inner part of the locking mechanism.
Kurt V
Old 12-02-2001, 10:20 AM
PRO Motorsports
Tyson Schmidt's Avatar
What commonly happens is the trigger breaks. The trigger can be replaced separately. You need to get one from another handle though. I don't think they are available otherwise.
The handle is held in by 2 10mm nuts. Window must be rolled up. The rear-most nut is accessed through a hole in the door that has a little tape over it from the factory. Use 1/4 drive socket and extension. Piece o' cake. Hardest part is getting the door panel etc. off.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 12-02-2001, 01:29 PM
