Alright....
Porsche_911s's Avatar
Front window seal is short on corners
I need some advice. I took the car in to get the windshield replaced by Clear Lake glass here in Clear Lake Texas. They ordered a new windshield and I used a seal from Pelican and reused the metal trim from my old window. The old seal was completely busted up and it did warp the metal some. I pulled the old windshield prior to going in and cleaned up the pinch lip and mating surface. Some rust but nothing major. Anyway, I am posting some picks because the corners of the drivers side are falling into the windshield concave. He said that the seal needs to relax in the sun for a couple of weeks and it will eventually fit.
Now.. take a look at the picks give some opinions. I know the pics suck but its the best at this time. He does plan on me bringing back in two weeks so he is not trying to bail on the job, I just want to get more eyes on it.
Stephen
Friendswood, Texas
'78 Targa
w/ '86 930/20
w/ '74 915/06
Old 04-02-2010, 01:39 AM
Rouxzy's Avatar
I had the same issue with mine. My installer had me go back in a week and he repositioned the window to fit. I don't know if that is what is up with yours but that is what happened with me.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 04-02-2010, 02:07 AM
Alright....
Not sure, I did not have this problem with my '74 coupe. When it was done, they did it in my drive way in about 95 degrees. It was also the original window though. That one popped in with some force but it was flush and a tight fit.
Hopefully the 80 degree weather will relax the damn thing.
Stephen
Friendswood, Texas
'78 Targa
w/ '86 930/20
w/ '74 915/06
Old 04-02-2010, 02:13 AM
(the shotguns)
berettafan's Avatar
Somewhat common problem. Can't help beyond that though.
Old 04-02-2010, 02:28 AM
Turboo934's Avatar
It's the glass , they sometimes need to be shimmed in the corners.
Robert. 1976 930/934 Turbo Carrera RRS, Cristine She can be evil but oooh so much fun
Old 04-02-2010, 03:57 AM
Unfortunately its pretty common. I had the same issue on my 82 SC using a new OEM gasket and the original windshield. The gap was in the left/right upper portion of the windshield.
Dan
Old 04-02-2010, 04:21 AM
Southern Class & Sass
Dixie's Avatar
you need to finesse the corners of the seal. Search, and you'll find the details on how to do this.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 04-02-2010, 04:26 AM
You use a wood form to bend the metal trim to move the seal into shape. It isn't (as I originally thought) just there to make it look better.
There are several threads but basically you take a piece of wood radius it to the shape of the corner hold it to the inside edge of the trim and tap it to move it into position.
88 Carrera Targa
04 Volvo XC-70
58 Harley Duo-Glide
96 BMW K-1100 LT
Old 04-02-2010, 05:00 AM
tof2.7's Avatar
we're lot in France , to had this probleme and after a search we have found that come bout the seal we have buying in a house who make porsche parts but re-made not original porsche. So we have buying this seal in a porsche shop and all is ok.
www.2l7registry.com the Ultimate register website for all 911 2.7 for 74 to 77
Old 04-02-2010, 05:21 AM
Throw it on the ground!
+1. Here is some info on how to fix the corners to close the gap. It's a pretty easy fix. Good luck. I still get some leakage in very heavy rains.....there are big gaps under that gasket and if some water gets in, its got to go somewhere. Good luck.
water leaks in footwells
Gap between Rubber Windshield Seal & Body
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 04-02-2010, 06:20 AM
dtw dtw is offline
GAFB
Good input in here. First make sure the glass is centered/square in the aperture. Then make sure they used some good glass - garbage aftermarket glass CAN cause this. If you have good glass, then you are down to 'massaging' the trim. I use a big soft rubber mallet. Tip - ensure the mallet and work surface are spotlessly clean or you will mess up the glass and trim. I keep a mallet that is used only for glasswork and carpets...just so it stays clean.
Several BMWs
Old 04-02-2010, 07:42 AM
Ruby911
ruby911's Avatar
As stated above, there is a good thread on this problem with the solution being a wood shim shaped to form the corner of the metal trim. Tap the metal trim lightly outward to push the rubber seal out over the gap - works like a charm. In my case, the fix would last for a couple of months, so I needed to place a small piece of scrap metal in the gap in the trim at the top center of the windshield. This prevented the metal trim from creaping back in. Did this a year a go and it is still holding strong.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 04-03-2010, 04:29 AM
Alright....
Looks like the bottom corner trim is not flush with the seal either. What is the best way to shape the trim? Should I cover it with cloth and use a rolling pin to try and push the trim into the seal?
Stephen
Friendswood, Texas
'78 Targa
w/ '86 930/20
w/ '74 915/06
Old 04-03-2010, 09:30 PM
Sounds like the trim popped out of the seal, and it is very hard to re-seat the trim with the seal installed, though some have done it on straight parts of the seal.
From reading your entire thread, here's what I'd suggest (you're probably not going to like it.) Remove the windshield, and remove the trim. Lay the trim on top of the seal and gently shape its contour to that of the seal as close as possible. Now, re-insert the trim into the seal and, most importantly, be sure there is a 3/8 to 1/2 inch gap between the trim pieces at both the top and bottom. As you've read, it's the trim that pushes the seal into the corners. Lube the seal and windshield lip well, and re-install, taking care the trim does not pop out. Once the windshield is seated, "massage" the trim, as mentioned in other posts into the corners. There will likely be a small gap remaining between the trim pieces if the seal is pushed into the corners.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-04-2010, 08:46 AM
