The post above took 12 seconds after the submit. Then it couldn't connect . . .
Ian |
I just rebooted the firewall, that's the only thing that has changed since the upgrade (the servers didn't change, just the connection). I have an email into the ISP provider asking for more information.
And that one took 2 secs.
Okay, let's see if those reboots make a difference...
-Wayne |
Okay, I had a phone conversation with the ISP guy, and he brought up some good points for us to try out.
-Wayne |
some throttling going on somewhere.
Assuming you're in your office Wayne testing the server in the same bdlg, you might be hitting only 3 servers in the entire path - like a 5 miles round trip maybe. I did a speed test from my home (Horsham, PA - verizon fios) to Phila (comcast test server - 50 mi rnd trip) and show 25.47M/23.9M down/up speed. |
That last one was fast
At the suggestion of my ISP guy, I just removed our firewall bandwidth restriction. It may be that our automated backup program is butting up against the connection and then causing real packets (from you guys) to become dropped. Not seen on our old connection, since we were limited by physical capacities of the lines. -Wayne |
fast........at the moment. edit....no, this post never showed up after a minute, then i clicked refresh and it showed then.
Am I posting too many pictures?:confused:
It's been fast with no bogging down or hang ups since I logged on this evening.
-Wayne |
It's behaving itself now, Wayne. Thanks for your efforts as always. http://forums.pelicanparts.com/support/smileys/clap.gif
Ian |
Seems pretty quick for me today...
I've been watching it quite q bit over the past few days. It's rocket fast right now. I think that issue with the backup was causing trouble.
Wayne |
testing
10 seconds,
I'm in Belgium, fyi |
I think I've fixed the problems associated with the move to the new location. There is still the occasional slowdown due to a complicated search or something like that, but those are relatively rare.
-Wayne |
| All times are GMT -8. The time now is 03:39 AM. |
