I have some rust in the battery area on an '86 Carrera. Also, thoughts on a tray?
I pulled my battery out a couple of weeks ago and found a few things I wasn't happy with.
- The previous owner put an Optima Yellowtop in which is nice and all. However, since it didn't work with the factory hold down clips, he used a couple of self tapping screws and drove them right into the body through the battery base.
- There's also an area of about 3" in diameter that's rusted, though luckily it's not too deep.
For the rust, I'll scrape away the factory rubberized coating as much as needed, buzz off the rust, prime with cold galv compound and then paint with black epoxy. I'll also fill in the holes from the screws.
The next question is, does anyone have any bright ideas on a battery tray? I'm thinking of getting some polyethylene (like a cutting board) and making something out of that but I'll need to anchor it.
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 12-20-2011, 12:22 PM
The cheap easy way is to find a piece of rubber roofing material Used for flat roofs. You can stightly heat heat it with a propane torch to allow it to stick to the metal. Buy the right size battery so you can use the stock hold down and rods.
Or
Old 12-20-2011, 12:33 PM
tharbert's Avatar
I'd also soak the area with some h2O/Baking soda to neutralize any residual acid.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 12-20-2011, 12:36 PM
I fully plan on doing that.
drcoastline, nice idea with the roofing membrane. I already have some of that on hand too, though I think I'll use my electric heat gun.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 12-20-2011, 01:11 PM
Enthusiast
jrolstin's Avatar
I'm also in need of a good solution for this as I have a similar problem.
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 12-20-2011, 01:33 PM
POR15 it not normal paint.
Old 12-20-2011, 02:31 PM
muck-raker
kidrock's Avatar
Por15, +1
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 12-20-2011, 02:59 PM
I'm not worried about fixing the rust. I'm more after battery tray solutions.
Thinking about the roofing membrane idea a bit more, I'm not totally sure I like the idea of gluing something to that. If I don't get all the rust, reoccur and I' wouldn't be able to see it. I think I'd prefer some sort of battery tray that I can remove for inspection. I'm going to keep thinking about this one though.
As for POR15, I'm not a big fan of phosphoric acid type anti rust treatments. I've used a number of them and I've had better luck with the technique I mentioned above. That is, mechanically remove all rust, prime with cold galvanizing compound and then paint. The typical paint I'll use is spray on black epoxy. This technique assumes it doesn't have to be too pretty of course. I've done hitch receivers using this technique and 10 years later, they looked great while the one on the same car with the factory finish had holes rusted in it.
That said, I'll take the POR15 recommendation under advisement.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 12-20-2011, 03:13 PM
Dublinoh's Avatar
if you search "optima battery tray" on ebay you will find a number of different solutions...I believe some would allow the use of the factory retaining system. Optima batteries won't leak so I like them..also red top is probably better for our application
Old 12-20-2011, 06:32 PM
deshetlr's Avatar
I bought an inexpensive tray from another dealer that uses the factory clamping system and almost disappears when installed.
Old 12-20-2011, 06:37 PM
PabloX you don't want to heat the roof material to the point it melts (like it is supposed to) just enough so it is tacky then it will adhere but you can pull it off by hand. The idea is it will put a barrier between the battery and the paint. ( also, when I said sticks to metal I really should have said sticks to the paint). Also as for rust treatment. Mechanically remove the rust as you stated. 962Porsche on the paint and body forum of this site recommends SEM Rustshield. It is chromated and will help prevent further rusting. The SEM is a dead match for the semi gloss finish Porsche uses on the floor pans and various other parts when mixed 1 part SEM to 8 parts hardener.
Old 12-20-2011, 07:10 PM
Is this a rattlecan product or are you mixing and then spraying with a gun? I searched for rattlecan epoxy earlier this fall and came up empty handed...
Old 12-20-2011, 07:13 PM
There is also marine grade battery boxes hold downs.
The black box version can be used with a standard battery. Find the location of your mounting holes and drill a hole through the bottom of the box use a bolt to hold the box in place. Put some silicanoe around the washer to make a seal. Drop the battery in. Of course an optima won't leak but if you use a standard battery now if it does the acid will be contained in the box. You could always cut the box down to about 1/2 it's height for better appearance.
Or one of these marine grade hold downs. But they don't offer any protection from acid leaks.
Just some thoughts.
Old 12-20-2011, 07:22 PM
cashman's Avatar
Do a search on "Optima". You fill find a template you can print along with hole locations that will work with the cutting board method. Very easy and secure hold down.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 12-20-2011, 07:29 PM
El Duderino
tirwin's Avatar
Not trying to hijack this thread but I have a question about the battery trays for the Optima red tops. Are the ones similar to the one in the link below sufficient for a DE event or do you need something like straps too?
Optima Battery Mounting Tray Kit for 74-89 Porsche 911 | eBay
Old 12-20-2011, 07:32 PM
cashman's Avatar
It should work. It is the same concept as the cutting board method and I have passed 2 DE inspections with no questions asked.
Old 12-20-2011, 08:00 PM
El Duderino
tirwin's Avatar
Ok, thanks! I have the cutting board but didn't know if it would pass DE inspection. Just thought I'd ask in case it would influence anyone's decision one way or another.
Old 12-20-2011, 08:28 PM
Sorry for the late reply on this one.
This is what I've used and the black is a good enough match for the black paint in hidden areas. It's certainly not something I'd use if I really wanted it to look pretty.
RustOleum.com
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 12-27-2011, 01:16 PM
Thanks. I'll look into that.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 12-27-2011, 01:19 PM
Senior Member
This is what I would use as well.
Then get a sealed battery and be done with it!
Old 12-27-2011, 01:46 PM
