dazed and confused
Removing rubber brake lines
Should I bleed the brake system system dry of fluid before removing/ replacing the rubber brake lines or just depress and hold the brake pedal down "with a stick"? I replaced standard bleed nipples with Speed bleeders using the brake pedal method; just wanted to be sure this approach would work when approaching the brake lines.
89 Carrera 3.2 Targa 2011 BMW 335d 2013 BMW X3 3.5 80 911 SC Weissach Coupe (Sold)
Holding the pedal down will work fine for the brake line replacement.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Senior Advisor
It will still make a mess, have everything ready to swap over the lines.
08 Cayenne Turbo |
Just did this like 2 or 3 weeks ago for the first time.
Hold down half way (or best you can) with 2x4 on the brake pedal against another 2x4 along the front of the seat. I just did this and barley lost a few drops from each line. A LOT less than I was expecting. I have all this extra ATE blue now I never used. I did a short pressure bleed on each before I started (recommended but not sure why). I found left over gold in the line/caliper, but which quickly drained to reveal the ATE blue that was already in the line. Then I propped the pedal down, then started the swap a wheel at a time. Then 3 bleeds - sat over nite, did one last one - used 1 liter can. I did not put fluid in the pressure bottle - I would de-pressurize and top off the res each time. You can do it. on edit: BTW - I did not bleed the slave cyl, but I'd swear the pedal action is better.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Northern Motorhead
I just replaced my complete brake system including calipers,master cylinder,front hard lines and stainless flex hoses all around and i survived the ordeal ... lol
In my case,the following did not apply ... Like Pete says,depress the brake pedal down a few inches with a 2x4 and you will hardly lose anything ! All you have to do afterwards is open your bleeders and gravity bleed them and then have someone pump the brakes a few times for a final round of bleeding. Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
RETIRED
I have ATE Blue and Gold on the shelf. I switch colors every change. When the color changes at the bleeder, I know I be done....
Just swap the lines and then bleed. I like the two person bleed system. One a pumpin' the other a bleedin'.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
