floorit426
Headlight Washers don't work
Hi,
I have an '87 Carrera with the High Intensity Headlight Washers. Neither one of them work when the headlights are on. I understand that they have their own pump. Does anyone know where this would be located? Has anyone else had similar experience? Thanks |
how full is your windshield washer tank? Mine stop working when the tank starts running low on fluid -- and resume operation when I top off the tank
Probably clogged up. Took quite a bit of compressed air and cleaning to get mine working again.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
On our '86, The pump is located in the boot, next to the condenser blower motor. Can you hear the pump running when you activate the windshield washer(s)?
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 04-08-2010 at 10:31 AM.. |
This might help.
Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Recreational User
Not according to the Bentley.
And please note that the headlight washing CKT is in the top left corner of the schematic.
Recreational User
Well, congrats! You found another error in the Bentley manual. Look on page 971-8 for the location of the windshield washer pump, and note it says exactly the same thing.
I replaced the headlight washer pump in my '86 a couple of years ago....it's attached to the washer fluid reservoir...I promise! |
floorit426
Thanks, for the great info. I will dig into today....but not without checking both locations, first!
![]() Thanks, Bill |
Born to Lose, Live to Win
not sure if the same on your car but mine has a dashboard switch which i discovered was dirty..thought mine were broken but cleaned switch and now they spray..though i dont use them because they cover entire car with fluid
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
Well, I tried........... Gerry
Been a while, but as I recall my non-operative headlight washers was nothing more than a kink in the hose. Easy to overlook, and can be hidden from view
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
