Upgrade to alum front cross member ??
I'm updating my 70T to an alum front cross member. The original steel one has two "straps", see red circle in pic. The alum unit doesn't have these. What did other pelicanites do for this ??
Robert Williams 70' 911T |
Buy a pair of straps used and put them on. I got mine here in the classifieds, they were like $40.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Get the later straps (as John mentions) and the later belly pan. I've been through this and it's a bummer when you think you're all done but the original belly pan won't work. As with the straps, the pan is a relatively inexpensive item.
304065 and JP911 are right on the mark regarding both the later straps and late belly pan - that's want I did when I went to the aluminum cross member on my '70.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Thanks guys for the insight.. guess i'm looking for both although I may make the straps.
AutoBahned
take a look at the PET before doing it - the straps are there with their p/n's as are some different washers, etc. from what you have
you save a few lbs. in doing this |
I made some straps out of 1/4"X1" stock - not easy to bend short lengths to fit, but very do-able still. I also re-used my old belly pan by just drilling 2 new holes to attach it to the underside of the alum. cross member.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
grateful user
Grind off you old straps and use them, very little mods required and fast and easy. Will have to drill the bolt holes where it bolts to the x-member. There is no value to the old one as far as I know, I cant give my collection of them away
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. Last edited by don gilbert; 04-07-2010 at 11:54 AM.. |
Thanks to all I plan to do exactly like suggested by Tom and Don
Home of the Whopper
I did the "upgrade" on my '73, but will not do it on any of my other cars. For the money, it just isnt worth it. You save a couple of pounds in an area that doesnt really matter. It is low, toward the front middle of the car, and not rotational or unsprung.
But it is cool! Just my opinion. Please return to the regularly scheduled program.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Hey, that's MY suspension!
![]() Glad my photos were useful. I'm glad to say all those parts are now cleaned up and reinstallation is happening practically as we speak. Mike
Michael Caterino Clemson, SC 1970 tangerine (=Tiger Orange) 'T' targa restoration: mk911.blogspot.com |
AutoBahned
true - not a biggie re wt. savings
(but I did it) now is the time to powder coat all the painted parts also a good time to put polybronze bushings on, check the fuel hose, brake stuff, rebuild pedal cluster, etc. |
gearhead
So you can do this without changing the A-arms? What about on a '68?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
AutoBahned
sure - dunno re a '68
I have a late belly pan freshly powdercoated black if you are interested.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
Air Cooled
I'd love to see a pic or hear more about this aluminum upgraded cross member...I'm new to air-cooled Porsches and would love to know more.
![]() Cheers, - CraigD
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Thanks for use of the pic Mike. BK911 - I'm replacing the A-arm bushings and thought while I was inthere .... I agree, not a performance thing, but does look cooler. I will post pics as I get into it. I will be home powdercoating a-arms and air cleaner while I'm at it.
Max Sluiter
You've already got one. It is just a model year upgrade that came with the 911SC.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
grateful user
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Air Cooled
hahahaI'm going into the garage right now to look at my aluminum cross member. ![]() Cheers, - CraigD
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 Last edited by Craig_D; 04-07-2010 at 08:44 PM.. |
