floorit426
Headlight Washers don't work
Hi,
I have an '87 Carrera with the High Intensity Headlight Washers. Neither one of them work when the headlights are on. I understand that they have their own pump. Does anyone know where this would be located? Has anyone else had similar experience?
Old 04-08-2010, 09:01 AM
how full is your windshield washer tank? Mine stop working when the tank starts running low on fluid -- and resume operation when I top off the tank
Old 04-08-2010, 09:22 AM
Scott R's Avatar
Probably clogged up. Took quite a bit of compressed air and cleaning to get mine working again.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-08-2010, 09:48 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by floorit426 View Post
Hi,
On our '86,
The pump is located in the boot, next to the condenser blower motor.
Can you hear the pump running when you activate the windshield washer(s)?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-08-2010, 09:53 AM
This might help.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 04-08-2010, 10:34 AM
Recreational User
porschenut's Avatar
Originally Posted by 86 911 Targa View Post
On our '86,
That's for the windshield washer. The headlight washer pump is attached to the outside of the washer reservoir, which requires removal of the valance for access.
Old 04-08-2010, 11:17 AM
Not according to the Bentley.
And please note that the headlight washing CKT is in the top left corner of the schematic.
1986 911 Targa.
Only in L.A.:
Old 04-08-2010, 07:19 PM
Recreational User
porschenut's Avatar
Well, congrats! You found another error in the Bentley manual. Look on page 971-8 for the location of the windshield washer pump, and note it says exactly the same thing.
I replaced the headlight washer pump in my '86 a couple of years ago....it's attached to the washer fluid reservoir...I promise!
Old 04-08-2010, 10:06 PM
floorit426
Thanks, for the great info. I will dig into today....but not without checking both locations, first!
Thanks,
Bill
Old 04-10-2010, 07:04 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
not sure if the same on your car but mine has a dashboard switch which i discovered was dirty..thought mine were broken but cleaned switch and now they spray..though i dont use them because they cover entire car with fluid
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 04-10-2010, 07:27 AM
Porschenut,
Well, I tried...........
Gerry
1986 911 Targa.
Only in L.A.:
Old 04-10-2010, 08:08 AM
rgrimm's Avatar
Been a while, but as I recall my non-operative headlight washers was nothing more than a kink in the hose. Easy to overlook, and can be hidden from view
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 04-10-2010, 05:01 PM
