MSD Wiring
I am installing an MSD 6AL in my 79 SC with MSD coil. Is there any problem with running the 12v hot line required to run to the MSD from an unused 12v hot connector on the fuse block/panel in the engine bay? This would be in the alternative to running the 12v source from the starter terminal and is a much easier hook-up. Thoughts? Thanks
Old 05-26-2010, 07:14 PM
Banned
I did it that way.
I researched here on Pelican first and found others had done it that way as well.
Old 05-26-2010, 08:07 PM
vash's Avatar
i did it to the fuses..then something fried..i took it to the starter ASAP. no issue ever since.
poof! gone
Old 05-26-2010, 08:57 PM
Senior Advisor
James Brown's Avatar
12V no problem, how many amps?
08 Cayenne Turbo
Old 05-26-2010, 09:36 PM
al lkosmal's Avatar
MSD6AL spec is 1A/1000 RPM. I would expect that a 8 to 10A circuit would do the trick for most applications. If I remember correctly the 3 position fuse block in the engine bay has 1, 8-10A fuse and two 25A fuses. I don't recall which circuit(s) is switched, but it should work OK load wise.
Regards,
al
PS: I ran mine to the starter though.........works good.
RGruppe #669
http://www.x-faktory.com/
Old 05-26-2010, 10:27 PM
Senior Advisor
Hey Al, just got the whole MSD 6al package and sending my dissy out to Berry for a recurve. It should work great with my carbs.
08 Cayenne Turbo
Old 05-26-2010, 11:45 PM
al lkosmal's Avatar
James,
MSD works great with carbs.
Al
PS: I'm working on an ITB'd 2.7 with EDIS & Megasquirt
RGruppe #669
Old 05-27-2010, 05:55 AM
red 2.7's Avatar
I did it to the starter with the msd installed on the brace between the shock mounts. I't a very short run and very easy. Works great with my carbs too. Barry did the dizzy and the idle just purrs. Throttle response is lightning quick.
Wally in Montreal, Canada
My age 50 something,P- Car's age 30 something 2.7 911S PMO 40's , E cams, RS pistons/cylinders, MSD6AL, Pertronix, SSI's, M+K 2 in 2 out. Perfect studs (whew!)
Old 05-27-2010, 06:20 AM
Hooked my MSD up to one of the 25 amp fuse connections in the engine bay. Works fine and you have a fuse incase of a short.
-Andy
Old 05-27-2010, 04:57 PM
fzr1k's Avatar
i have an 82 sc with a 6al and blaster coil and would suggest running the wire to the starter as i did. also when u hook the pickup wires if they are reversed the car will run badly backfiring and sputtering so if this happens reverse the pick up wires i chased this for a long time.
82 911 sc coupe guards red sunroof coupe
msd 6al and blaster coil ,cat bypass,9.8:1 comp,heads shaved.020 mild port and polish, 964 cams, k&n filter and cut airbox lid
If I wanted your opinion I'd beat it outta you
Old 05-27-2010, 06:57 PM
jdowty3's Avatar
old MSD setup
new setup about to hit the road
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 05-28-2010, 06:10 AM
