I'm no welding expert but wouldn't you want to weld it with the case bolted together to keep it from distorting? Maybe weld it and then take it apart.
Rick 88 Cab |
If it is weldable and I flush out the bottom end to make sure there isn't any metal parts lying inside do you think I will still need to split the case? It is a very clean break and already got a 10 Litre flush. |
The hand wringers will disagree but I bet I could have you on the road in weell under 4 hours (+epoxie set time) using $5 worth of stuff. YES any welding will require the case to be split. Mag flows heat too well and the entire case will get real hot. Last edited by Green 912; 04-13-2010 at 09:26 AM.. |
JB weld?!
What happens on the highway, at speed, as you dump 10 quarts of oil?... Forget about toasting your motor, thats the least of your issues... You will be in court for the next ten years as all of the cars in your wake wipe out... Thats a lawyers wet dream... |
3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
As he looks at the jury, "Your Honor! I read on the internet that this was totally safe..."
Defendant, call your next witness! "Your honor, I call kenikh..." Could happen...
When I was machining, we used to do repairs on similar repairs on all sorts of cast housings.
There is no permenant repair (in my opinion) without removal of the case and taking it to a machine shop. you can have them set it up on a milling machine, bore the hole round (it is surprisingly round now), mill a step or spotface on the surface and drill and tap about 8 holes around the diameter of the step. They then make a stepped plug out of aluminum amd bolt it on, no welding, no warping and you have a sweet access hole that no other 911 has. Bad thing is, you have to do it out of the car. I'm in Saskatoon, and there are lots of shops here that would do it, I'm pretty sure that someone in Yorkton could do it. Glad to hear you weren't under it when the jack let go. |
Although I would like to be in the court room when the "Epoxy" guy was on the stand that would be interesting.
Well the insurance people want 3 quotes to get it fixed. Good luck for that. Any ideas if removing the motor for a case swap would be cheaper than finding a rebuilt motor ready to drop in? If so, without me having to piss around on the net, anyone know what motors will drop in this car? Be nice to keep it under $5 grand shipped.
As the displacement incleases you will need to face issues such as making sure the transmission can handle the power, proving adequate cooling, getting the electricals to match up etc.
I don't think the adjuster realizes how expensive this can be to fix. You could do it yourself for several grand with a used engine, and several months of spare weekends... |
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Burn the fire.
Wow, almost looks like a perfect circle.
I would second the opinion of needing a new engine. Time to build the one you've been wanting... Also this serves as a reminder to others to not put a jack stand under the engine or transmission. There are structurally sound positions all over the car for supporting it with jack stands.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
As noted if you ask a Porsche dealer for a quote to "Replace engine case" SGI will write off your car.
Bunch of old cars
I seem to remember that a new case from Porsche was about $4,000 - I was looking at getting one for my S a while back, but decided to do the machine work to keep the original case number.
The machine work was about $1,500 and included resizing the case back to standard, pistons squirters, case savers, etc. Personally, I think the best option would be to find an early sandcast aluminum case and rebuild your engine with the correct case for the car - it should run about $1,000 for the case and becasue it's aluminum, you probably won't have to do the expensive resizing machine work. Regards, Andrew M
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
So I can use that new alum case and just attach all my original parts onto it with no problems?? Hopefully?
Yes - I think you said the engine is a 69, so it's probably still a 2.0. All the pieces should bolt up no problem.
In my track car, I currently have an aluminum case based 2.6 and I love it. You could use this situation as an opportunity to build up a hot rod 2.0 or something. Regards, Andrew M
I would rather be driving
Just think with the aluminum case it will have protecting ribs in that area.
![]() Glad to see so many great suggestions. I would be tempted to try the epoxy fix while I was shopping for a new case/motor.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Alright, its motor case shopping time. Will definately tweak that little 2.0 to get some more ponies.
at least it not an early aluminum case. The 2.0 Mag cases arent too dear..
Bruce |
