Should I Really Use Lithium Grease on Pedal Assembly?
After months of getting everything lined up on my pedal assembly (powdercoat, springs, new shaft, etc). I am putting it together this weekend, but I think I read in Wayne's book that he used Lithium grease. I am figuring that out of all the parts in this car that gets pretty sandy or gritty it's the pedal assembly, and thought that maybe light oil might be better than the Lithium grease that will attract grit, dirt, moisture and everythingthing else. Was wondering what you guys use or used on it for assembly.
Old 08-10-2013, 12:29 PM
kodioneill's Avatar
Copper based never seize.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-10-2013, 12:38 PM
AutoBahned
RWebb's Avatar
clear grease from Wurth would perfect, with white grease as 2nd choice, since the mess if any gets elsewhere will be limited; anti-seize will work but can make a huge mess
grease will stay there, but oil will run out
grit will eventually grind away at the moving parts so replace them every few centuries
Old 08-10-2013, 04:45 PM
